PX4 Sync / Q&A: Mar 05, 2025
Dronecode Calendar
Agenda
  • Announcements
  • Future Events
  • Flight Testing Update
  • Release Discussion
  • Bug Report / Q&A
Announcements
Maintainers Meeting
  • We need to discuss a few Quality and Functional Safety improvements
  • Including release cadence, and testing updates
  • All maintainers should join, an agenda will be distributed shortly
  • Ramon will be contacting everyone directly via email to coordinate a date/time
Next Dronecode Meetup
Philadelphia, Pennsylvania, USA
Future Events
The team at Ascend Engineering (Chicago). are running flight testing for the community.
How to reach out to the team
  • GitHub: Tag user @PX4/testflights
  • Discord: #flight-testing
  • Weekly on the PX4 Dev Call
How to Request Testing (GitHub)
  • Write down the steps to test your issue/pull request
    • Make sure to note the risk involved in flying
    • Write down things to look out for / anticipate - eg: “we are looking for no yaw jumps”
  • Add issue/pull request to the Flight Testing project board
  • Make sure to specify any hardware/software requirements as much as possible
Resources:
Comments / Discussion:
  • Are we testing Fixed Wing / VTOL: not yet, but platforms are available for bringup
  • Are we using QGC Daily or Stable: Stable for now, we want to switch to Daily, but once video streaming is fixed in daily.
Release Discussion / Updates
v1.16 Release Discussion
  • Fixed Wing known blockers: @sfuhrer none on top of mind
  • Multi Copter known blockers: @MaEtUgR none on top of mind
  • Optical Flow: @AlexKlimaj we should likely get height estimate fixed in main
    • @dagar Let’s check the logs to make how to controllers are configured
    • TODO Let’s make a Test Case for the flight test team so we can validate
  • Simulation known blockers:
Resources
Bug report / Q&A
[Bug] PX4 Min PWM & Disarm PWM set to same values
Self assigned to @farhang :
PRs needing review
Remove random walk from gazebo-classic models. Currently causing CI SITL tests to fail frequently. See comments in PR:
Discussion:
Let’s have a quick sync between @dakejahl and @Jaeyoung-Lim @dagar so we can address his isssue and fix the overall problems
PR further improves the build system and adds a template as an example. Docs and gstreamer plugin to be coming:
An opportunity to add an ocean world with waves. A barge with an aruco tag would be sweet for testing ship takeoff and landings. This has been a feature people ask about for years. Any other interest? (Relevant plugin repo: GitHub - srmainwaring/asv_wave_sim: This package contains plugins that support the simulation of waves and surface vessels in Gazebo. · GitHub)
Want to talk about this as there is some weird behavior when selecting x500 v2 (which is a pretty common airframe)
Also want to talk about this
as I can see people getting stuck when updating firmware versions and wondering why their VIO is no longer working
I won’t be on the call tomorrow but there are just a couple of things I wanted to bring up for comment from others.
Remove random walk from gazebo-classic models. Currently causing CI SITL tests to fail frequently. See my comments in PR.
I’ve been doing a large scale refactor and improving gz sim integration. Recently I added custom plugin support (optical flow), this PR further improves the build system and adds a template as an example. I just wanted to share this, I will work on docs once it’s a little further along. Stay tuned for a gstreamer plugin.
I think we should use the opportunity in this PR to add an ocean world with waves. A barge with an aruco tag would be sweet for testing ship takeoff and landings. This has been a feature I’ve seen people ask about for years. Any other interest?
Plugin repo for the above, for adding waves and surface vessels
Test Card process updates
Updated px4-dev container
  • native multi-arch support for x86 & arm64
  • based on ubuntu 24.04, using new ubuntu.sh
  • installs gcc 13 via apt
  • replaces older containers in our CI infrastructure:
    • Builds the board matrix with them
