Does PX4 support brushed motor controllers, as in “Brushed with Relay” for directional control. My requirement is to use a drive motor back and forth and a another DC motor for steering. (Planning to use wheel encoders for both motors) as well. Help me out please
I would think that PX4 supports whatever interfaces with PWM (or DSHot). Whether the controller itself is brushed or brushless shouldn’t matter.
In terms of direction - so the ability to go backwards - this was long a tricky thing but I would hope it’s solved by now, maybe @Jaeyoung-Lim can chime in.
@Christian_Friedrich Is our new resident expert on Rover, in particular for PX4 v1.16 and later.
If you’re using an earlier version all bets are off - you should upgrade.
@Christian_Friedrich will you be able to guide regarding or provide a reference for the task please
That’s not how it works. Start by reading the documentation Rovers | PX4 Guide (main)
When you have a specific question about what you want to do, having read the documents, come back with information about what you have tried and where you run into problems. In that response include information about the vehicle type, and any problems you had.
