PX4 - NSH TOP command not working
Hello everyone,
I am running a Cube Orange with the PX4 Firmware Stack Version 1.12.3.We are trying to run a custom controller setup in which we test an experimental controller or an experimental setup.
We could successfully, compile and upload the PX4 Firmware to the Cube Orange, however whenever I run the “uorb top” command in the nsh shell (in order to list all uorb topics), nothings happens. The exact output is:
nsh>
nsh> uorb top
nsh>
does anyone have a hint or knows what happens here? Why does this command not work. Other commands seem to work fine, also I get correct telemetry from the board so obviously uorb HAS to work right? Also If I enter “uorb status” for example, I get output. So what is going on here?
Best regards,
Phil
Even I am seeing the same issue on Pixhawk 4 with Mavlink shell.
Same problem with my Pixhawk 6C.
NuttX-11.0.0
Latest PX4 (compiled by sources today 28/12/22)
Same with PX4 1.13.1 on Cube Orange
Apparently it works with uorb top -1
uorb top not works,
uorb top -1 works
