PX4 driver for the ranger finder sensor
Hi there, this is Zhenyu, from Ainstein AI. We have a radar range finder sensor that has been officially support by PX4 for a while, and it is the serial port interface one. Recently we have several clients asked about the official support for the CAN interface one, so I am wondering what is the procedure for us to do it?
Our CAN interface US-D1 radar range finder sensor use the private data format, 1Mb/s bit rate, CAN 2.0B standard.
You need to modify your driver to listen for CAN messages. Have you tried doing this yet? If so, please send a draft pull request so we can help you.
It’s likely better if you can join one of our developer calls so we can guide you on approaching this.
Thanks for your response @rroche .
Is it possible for Ainstein to create a new driver for the CAN interface, and let the serial port drive as it is?
yes, creating a new driver is possible if that’s what you want to do
@rroche Thank you so much for your reply.
For CAN driver, there are two paths for Ainstein US-D1:
  1. Exclusive driver for US-D1 own private CAN protocal, like my original post.
  2. We also consider to update the US-D1 firmware to support (or compatible) DroneCAN. Since PX4 has already support DroneCAN driver, it would be OK to support US-D1 with DroneCAN protocol.
It seems like we are decided to go to the option 2, and we will evaluate whether it is still worth to do the option 1 as well. If we do, we will arrange manpower to work with PX4 team to achieve it.
@Zzzhu Did you finish this integration effort? Is the US-D1 supported by PX4 now?
US-D1(CAN interface unit) now is compatible with DroneCAN, users can configure US-D1 to DroneCAN and integrate it to PX4 when it is also configured as DroneCAN.
Please contact Ainstein for more details.
