September 08, 2021
Join us
Agenda
- Community Q&A
- Roadmap
- High priority queue
- Release
- In-Depth discussions
Announcements
- Next week the developer call is canceled because we’ll be at the PX4 Developer Summit.
Community Q&A
@david_s5 12 cell Li-po/ion power module support: So far fmu-v5x usually comes with a 6S compatible INA226 power module. Holybro will be providing a power module with an INA228 on to support 12S batteries. The software support for it to work out of the box is currently work in progress.
@MaEtUgR Pull request to allow configuring a margin for the horizontal multicopter control authority when the vertical control is saturated: MulticopterPositionControl: add horizontal margin for vertical saturation cases by MaEtUgR · Pull Request #18205 · PX4/PX4-Autopilot · GitHub
@david_s5 and @rroche had an issue recently where the virtual joystick would make an autopilot to beep for presumably failsafe when using it over USB:
QGC when Virtual Joystick enabled FMU goes to Fail Safe connect on USB · Issue #18054 · PX4/PX4-Autopilot · GitHub -
Vatsal Joshi: What are the instances where you get a PWM count error. He’s configuring PWM and then tries to test it but gets the error. It’s likely a configuration issue.
pwm_out testshould get all outputs to fade from low to high values. -
Dave Walter: Is contributing to the documentation explicitly on how to integrate a stand-alone smart gimbal with MAVLink and PX4: Integrated Camera/Gimbal Systems Documentation · Issue #1678 · mavlink/mavlink · GitHub
In the hope to get better manufacturer integration from e.g. Trillium, Nextvision, … so if you’re a manufacturer or gimbal-interested developer chime in. @JulianOes is very interested and already joined the discussion. -
Farhang Naderi: Asking what should be tested. Please test the new point release especially also with the newest boards. Thanks!
Release
New point release is out 1.12.3:
Roadmap
Discussion based on board: https://github.com/orgs/PX4/projects/25
High priority queue
Discussion based on board: https://github.com/orgs/PX4/projects/24
- Device tree: It would be nice to have a UI showing what devices are connected on which bus and the user can select what to enable and it will be required from thereon.
