PX4 Dev Call: October 30, 2019
October 30th, 2019
Agenda
  • Status update by component
  • Release v1.10
    • Time for another beta? should we cut an RC?
  • Join the discussion on the Pixhawk Hardware Standards Call
    • Currently discussing
      • Payload Standardization
      • BMS Standardization (Smart Battery)
      • Many other topics, including FMUv* and UAVCAN devices.
  • Introducing the Volunteer Team
    • Inbound Messages, Flight Testing Support, Assist Component Owners
  • Open section for the community (Please add your agenda items)
    • Anyone can propose topics for discussion
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: Zoom International Dial-in Numbers - Zoom
Component update
Documentation
Small usability fix to the parameters list. Booleans are now documented and you can see the default state. See ATT_ACC_COMP.
Flight Testing
Bad weather remains in TJ, fires and very strong winds, unsafe for the team to out to the field some days last week, and this week as well.
Weekly Report
System Architecture
@dagar
https://github.com/PX4/Firmware/pull/13103
OS / NuttX
NuttX/nuttx with SDIO fixes
From last week’s conversation on filesystem read/write issues, this PR updates the NuttX submodule with the upstream fixes.
https://github.com/PX4/Firmware/pull/13311
Comms
MAVLink update from bi-weekly meeting
Microservices was the main focus of the call
Meeting minutes for MAVLink call
Driver
@mcsauder looking into issue #13316
https://github.com/PX4/Firmware/issues/13316
@dagar Added ICM20602
Commander
@JulianOes A corner was discovered in the failsafe state machine
Action: Send PR to release branch (once we figure out what’s going on)
https://github.com/PX4/Firmware/pull/13294
VTOL
@sfuhrer This week we are flight testing the airspeed sensor PR.
Action: More testing by @sfuhrer
https://github.com/PX4/Firmware/pull/12887
@igalloway NXP is working with FliteTest to produce a low-cost VTOL with PX4
Fixed Wing
:point_up: Same airspeed PR as VTOL with testing by @sfuhrer
Multicopter
Refactoring in master
Bug fixes for the release
Track down the PRs and issues
MAVROS / RTPS / ROS2
@TSC21 Currently working on the CI for px4_ros_com in order to add tests to the microRTPS bridge functionality
Avoidance
@jkflying fixes went into master
https://github.com/PX4/avoidance/pull/520
https://github.com/PX4/Firmware/pull/13321
Release v1.10.0
Battery fixes and Nuttx fixes
Action: make sure those are in the release branch
Action: cut a beta5 once those fixes are in
make sure we check on this issue before release
https://github.com/PX4/Firmware/issues/13147
@mcsauder & @dakejahl when we went from 1.9.2 to master we burned two motors (400Hz PWM)
Action: @david_s5 sending a PR that enables two-wire ethernet on the K66
Question: @igalloway I have a general question at some point - relating to localization and how this should integrate with GPS positioning. How to transition from one to another localization system.
Answer: @jkflying Estimate offset between one and another, so you can get a smooth handover. You need both overlapping at some point.
Work Group invitations, BMS & Payload
Errata and Feedback
