PX4 Dev Call: December 18, 2019
December 18, 2019
Agenda
  • 1.10 release is out! Twitter announcement, release notes
  • Next two dev calls cancelled due to holidays.
  • Status update by component
  • Open section for the community (Please add your agenda items)
    • Anyone can propose topics for discussion
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: https://zoom.us/u/aetSYKbiMF
Component update
Documentation
Flight Testing
Weekly Report: 43 test flights, 4 PRs, more info here: Week 45 December 9- December 13
System Architecture
OS / NuttX
  • Move to Apache incubator in progress.
  • IMXRT: prototypes have arrived, board is up and running, @david_s5 is working on various issues as they come up. NuttX patches will probably be backported for now, and then come in the next NuttX release.
Comms
  • No update
Drivers
  • Distance drivers in the 1.10 checked by @mcsauder.
  • Question about state of mpu6000 options of different drivers, etc. @david_s5 and @mcsauder will follow up.
Commander
  • No update
VTOL
  • No update
Fixed Wing
  • No update
Multicopter
  • Position controller refactoring number 5 went in: https://github.com/PX4/Firmware/pull/13701
  • Refactoring of smooth waypoint stuff is ready and has been flight tested. Removed old mission line tracking for flash space. Avoidance will be re-tuned to use the new smooth waypoint instead of the old mission line tracking: https://github.com/PX4/Firmware/pull/13596
  • Discussion about fmu-v2 flash space again:
    • @LorenzMeier suggesting to have variants of fmu-v2 and the option to select them in QGC.
    • @david_s5 suggesting to automate the bootloader update to get numbers on fmu-v2 vs fmu-v3.
    • @JulianOes representing @dagar and @bkueng which vote to keep working/optimizing on flash space.
      -> to be followed up in a separate dev call!
MAVROS / RTPS / ROS2
  • No update
Avoidance
  • Little bugfixes, change on firmware side mentioned above.
  • Junwoo Hwang asking regarding documentation:
    • Documentation more describing the code would be helpful.
    • E.g. how to implement a specific feature, how does avoidance, position control, mission smoothing, etc. all work together from an architectural standpoint.
  • Timeline for next release?
    • @jkflying suggesting to do 4 releases per year instead of 2.
Errata and Feedback
Commander:
Multicopter:
