PX4 Dev Call: August 10, 2022
August 10, 2022
Join us
Agenda
  • Community Announcement
  • Community Q&A
  • Project Updates
  • General Discussions
  • Weekly Overview
  • High priority queue
  • Release
:loudspeaker: Community Announcement
:people_holding_hands: Community Q&A (No deep technical discussions)
:exclamation: Guideline for asking a Question
  1. Specify what you are trying to achieve
  2. Specify what environment / platform you are using
  3. Prepare a Link or Document to help understand if possible
  4. First, ask the question on the Slack or create a Github Issue!
  5. If you take over 5 minutes for the question, please continue in Slack or a Github Issue.
Q.1 : How does MAVROS co-exist with DDS? - Michael
Have a custom MAVROS for ROS2, and have been using PlotJuggler for plotting live during flight.
  • With direct DDS communication, the translation of MAVLink message to ROS topic would be eliminated, which is convenient :+1:
  • DDS connection may suffer from lossy connection (e.g. Over the Air Telemetry Radio), so MAVLink communication can be better there
Q.2 : Control allocator trim - Chris
Let’s say we have 1000 ~ 2000 us range Actuator. And you need to trim it to one side. Would it then leave a ‘deadspace’ in the maximum control signal? (Or does it linearly map the input to output so that we still have full range of motion?)
  • The trim should be in the hardware level (e.g. PWM in microseconds)?
  • But that would lead to *multiple trim settings for different output protocols (CAN, PWM, etc)
Q.3 : Airspeed integration for control allocation
It is still unclear if we want to bring the airspeed consideration into control allocator, but would be nice to discuss together.
  • Shared Rate controller
Q.4 : uBlox driver
Made a change in driver to enable RTCM passing through directly to the Rover
  • Currently for Rover startup script, it disables UART2.
Currently for Underwater Robot SITL, we are not using hydropressure sensor data, and is now using barometric data.
:construction_worker_woman: Project Updates
P.1 : Transition to XRCE-DDS compatible PR coming soon
Exciting possibility of having real-time PlotJuggler plotting generic uORB data via DDS connection :+1:
Timestamp setting discussion
https://github.com/PX4/PX4-Autopilot/pull/10178#issuecomment-411137933
  • Would be better to consider it as a ‘metadata’ instead of a mandatory field user needs to fill in when publishing a uORB message.
P.2 : uORB Service Implementation
https://github.com/PX4/PX4-Autopilot/pull/19921
  • Where is the ROS2 implementation / metadata architecture? → RMW libraries &
P.3 : Multiple height sensor fusion - Mathieu
Would love to get feedback & test logs!
P.4 : Helicopter bringup is coming soon - Matthias
PR is coming up with all the learnings :helicopter:
Still working on a nice ramp-up (spool up) behavior.
And found a bug in Multicopter Attitude controller
:thinking: General Discussions
D.1 : Geofence Altitude limit overshoot bug
@DPatrick has a good understanding of this issue and may join the call to discuss this.
D.2 : Momentary switch activated mode/ transitions - Chris
There is a stale PR that tried to implement this:
:calendar: Weekly Overview
:mouse2: Github
Recently updated Issues / PRs in PX4-Autopilot Link
Pull Requests
Issues
:computer: Slack
:phone: Last Dev-Call
PX4 Dev Call: August 03, 2022
:exclamation: High priority queue
Discussion based on: https://github.com/orgs/PX4/projects/24
:ear_of_rice: Release
Great notes, thanks for that!
