August 04, 2021
Join us
Agenda
- Community Q&A
- Roadmap
- High priority queue
- Release
- In-Depth discussions
Community Q&A
@david_s5 is asking for flight testing on the NuttX changes: https://github.com/PX4/PX4-Autopilot/pull/17653
All the bench tests with all the drivers succeeded. It would be nice to have someone verify there’s nothing different in a real flight. Otherwise this will probably get merged soon. -
ECL was merged into the PX4 repository and the repository will be archived.
The latest fixes will get ported to a point release on 1.12
The reason for doing that is a lot of maintenance cost for no benefit. There’s only some issue during transitions but we will get over those soon.
We’re considering to also merge the Matrix library. -
Vatsal Joshi: Support for the Raspberry Pi microcontroller board
RP2040 MCU Support by vxj9800 · Pull Request #17966 · PX4/PX4-Autopilot · GitHub
NuttX has support even for dual core use.
For a start using MPU6050 I2C tested first
plan to use MPU6000 over SPI
Discussion about NuttX support -
Dhruv Upadhyay: Is interested in getting closer into the dev team and is looking for a good issue to start with. He’s currently interested in low-level driver work but currently doesn’t have hardware access.
- Something really useful but not too easy might be to solve the bus reset problem. Such that drivers don’t have to handle bus resets one by one but there’s a general automatic structure for that.
- BLHeli passthrough is an idea. BLHeli ESC connected to the flight controller can talk through it to the BLHeli tool on the computer.
- Suggestion to continue gudance on the #hardware channel on Slack
@dagar Output mapping discussion
- The IO lobotomy, moving IO mixers to FMU needs to get in:
https://github.com/PX4/PX4-Autopilot/pull/16444 - @Jacob_Crabill 's configuration pr can get fully tested and merged after that:
https://github.com/PX4/PX4-Autopilot/pull/16808 - @bkueng has plans and suggestions for the architecture goal that we might want to discuss soon.
Discussion about UAVCAN v0/v1
How to decide compile time what’s supported and how to enable one or the other runtime.
Roadmap
Discussion based on board: https://github.com/orgs/PX4/projects/25
High priority queue
Discussion based on board: https://github.com/orgs/PX4/projects/24
Release
Release 1.12.1 is out https://github.com/PX4/PX4-Autopilot/releases/tag/v1.12.1
There will likely be another point release with the latest ECL fixes mostly because of this very helpful finding: EKF covariance prediction stability improvements by bresch · Pull Request #1026 · PX4/PX4-ECL · GitHub
For smaller groups expanding technical discussions, stay until the end and follow up.
