PX4 custom flight controller porting
hi, I am currently working with px4 custom board development, I got stuck with the final step of the NuttX Board Porting Guide. I was done till this part.
"make manufacturer_my-target-v1 menuconfig"
but it shows an error like this:
''CMake Error at platforms/nuttx/CMakeLists.txt:64 (message): NuttX custom board directory (../../../../boards/px4/fmu-v6c/nuttx-config) isn't in board directory."
please help me with it.
I also faced same error but i fixed this by editing the def config files in the custom_manufacturer (it may depend on what you have named the board under which manufacturer) folder to reflect the paths as same as your custom board in CONFIG_ARCH_BOARD_CUSTOM_DIR variable.
There will be two defconfig files in the nuttx folder, you have to change it both as I stated above. One will be under nuttx-config/bootloader other will be under nuttx-config/nsh of your custom board directory.
Hope this clears up everything.
Regards.
DKR
