PX4 Community Q&A: April 19, 2023
April 19, 2023
Join us
Agenda
  • Community Announcement
  • Community Q&A
  • General Discussions
:loudspeaker: Community Announcement
A.1 :
:people_holding_hands: Community Q&A (No deep technical discussions)
:exclamation: Guideline for asking a Question
  1. Specify what you are trying to achieve
  2. Specify what environment / platform you are using
  3. Prepare a Link or Document to help understand if possible
  4. First, ask the question on Discord or create a Github Issue!
  5. If you take over 5 minutes for the question, please continue in Discord or a GitHub Issue.
Q.1 : VOXL 2 Support in v1.14
We discussed a few PRs that add support for the VOXL 2 from ModalAI on the call.
https://github.com/PX4/PX4-Autopilot/pulls/katzfey
Q.2 :
:thinking: General Discussions
D.1 :
I would like to discuss ModalAI PRs 21426, 21427, 21428, 21434, 21435, 21436, 21437, 21472, 21474, and 21477.
I would like to discuss implementation of a platform independent UART API. Here’s a first cut with a working platform implementation on Qurt platform: Comparing voxl-dev..uart_interface_experiments · modalai/px4-firmware · GitHub
Can we also discuss MC_Pos_Control: takeoff bug constrain hover_thrust_estimate by hendjoshsr71 · Pull Request #21380 · PX4/PX4-Autopilot · GitHub? I think we may have just seen this on 1.13 and had the drone go full speed into the ceiling!
Hi, I have a question about VIO. Is there any example of the VIO bridge ROS node that provides a bridge between a camera and ROS? If yes for what version of firmware is it compatible with? Previously I was trying to use Autherion VIO bridge but it is not available now – (github page is not found). Do you know if Autherion would modify it’s VIO bridge?Question about VIO bridge- If I am working with EKF2 camera data should be streamed to /mavros/odometry/out or /mavrosvision_pose/pose?
Second case, what are the appropriate mask settings for the ekf2_ev_ctrl to fly drone with VIO and missing temporary GPS.
I have a quick question, I’ve been having the PARAM_VALUE mavlink message poping up in the Iridium mode on an interface. But I’m not able to replicate that consistently.
I was wondering what could be generating PARAM_VALUE messages being sent on the Iridium interface?
As discussed on the call we would like to help you with VIO please open a github issue and we will help you debug.
Link to my github issue : Problem with VIO bridge · Issue #21498 · PX4/PX4-Autopilot · GitHub
