This is my first time using PX4.
I am using pixhack v3.
The instructions I use are:
Make px4fmu-v3_default upload
Will always pop up the message “If the board does not respond, unplug and re-plug the USB connector.”
By the way, I compiled successfully with “make px4fmu-v3_default”
This problem has been bothering me for a long time, I hope to get a solution.
Have you checked this?
https://dev.px4.io/en/debug/faq.html#usb-errors
What is the output of lsusb during the first 3 seconds when you plug it in?
Do you have the permissions necessary?
https://dev.px4.io/en/setup/dev_env_linux_ubuntu.html#permission-setup
Of course, I do the “Permission Setup” and “Remove the modemmanager”, but it still can’t work.
Here is the result of lsusb.
And you’re inside a VirtualBox and you have installed the VirtualBox extensions and guest additions?
And after the permission setup, you logged out of Ubuntu and back in?
What is the output of ls /dev/ttyACM*
