I am trying to connect a water pump to my octocopter coax which has pixhawk4 and px4 on it.
The pump has separate 12v battery and a +,- and S wires. Can you please advise where should I connect these 3 wires on the PMB (PDB), and how to set it up in QGC to a specific switch on the controller?
Figured out on our own. In case anybody wantโs to do the same. Use AUX 1 ports on the power board. So connect a thin (white, red, black) cable to the AUX 1 port. Then assign a switch in QGC to trigger this port and there you go.
