PWM signal analysis through mavlink messages
I am trying to look at the PWM signals using the servo output raw mavlink message on the UAV with pixhawk 4 board running px4 firmware v1.14. However, I can only see the message on Qgroundcontrol while the UAV is connected by a wire whereas I need to access the message through a wifi connection. I also cannot see actuator output status mavlink messege at all when connected by wire/wifi.
Is there anyway to see PWM signals through a wifi connection without having to modify px4 firmware?
Thanks.
