Hello, I’m having a problem using multiple sensors in PX4. I connected 3 MB1242 sensors and their I2C addresses are set to be 112 (71 in hexadecimal), 113 (72 in hexadecimal), and 114 (73 in hexadecimal). In the MAVLink Inspector of QGroundControl, only the sensor with the address 112 gives distance input as “DISTANCE_SENSOR”. The sensors that have other I2C addresses other than 112 cannot be started. Should I set different I2C addresses to the other sensors or is there any solution for that? Thank you.
