I would like to implement the same with a companion computer in Offboard control with MAVROS. My question is there a service for precision landing with IR lock that should be called to perform a precision landing like the MAVROS (~cmd/land (mavros_msgs/CommandTOL)) for normal landing? If not, can someone please give me some pointers to implement this.
You can easily initiate a precision landing by uploading a mission that ends with a land waypoint with the appropriate parameters as described in the dev guide.
@Nicolas Thank you. Yes, I have tried the precision landing with appropriate parameters using QGC and it works well.
Now I’m trying to initiate a precision landing using MAVROS from a companion computer (e.g Odroid). I was hoping if someone could give me pointers how to implement this.
Precision landing is also a flight mode of PX4 (when not used in a mission). So if you don’t want to upload a mission with mavros, what you should be looking for is changing the flight mode appropriately. I’m not sure if mavros is already capable of setting the precision land flight mode.
I am trying to precisely land a UAV with PX4 firmware(Pixhawk 6C) using IR Lock sensor and Beacon through QGC. I have followed the steps properly as mentioned here(Precision Landing | PX4 User Guide (v1.12)). The drone lands normally without precision. After reviewing multiple times, i found that IR lock driver is not starting even after forcefully starting it.
The same setup works perfectly on Ardupilot firmware on a Cube Orange Plus flight controller through Mission Planner GCS.
