Hi, I connected a xbee telemetry module to my pixhawk 1 but the pixhawk stop getting signals from the GPS. In MissionPlaner says ‘GPS: no GPS’ and in the hardware of the GPS there’s only a blue light sparking. Before i connected the xbee the GPS worked well. Any advice?
If you’re using MissionPlanner you’re likely using ArduPilot and should ask in discuss.ardupilot.org.
I solved the problem reinstalling the firmware. I hope this helps some one.
