I have a pixkawk Radiolink - I cannot get the RTK working .Can someone please give me some tips to try . I verified the gps on Skystars h7HD and it works fine - basically there make be something I am missing to get the RTK on my Radiolink Px4 set up . Any advise will be appreciated .
does the pixhawk 4 with with RTK ?
Yes – Pixhawk 4 (and most Pixhawk-class boards) support RTK in PX4. When RTK “doesn’t work”, it is usually one of these:
- The GPS itself must be RTK-capable. M8N/M10-type modules (often bundled with Radiolink kits) cannot do RTK. You need an RTK receiver (e.g. u-blox F9P, Septentrio mosaic, Unicore UM98x) on the drone and a source of corrections.
- Corrections must reach the drone. Either a base station connected to QGroundControl (Application Settings → RTK GPS, let Survey-In finish) or an NTRIP caster, with QGC forwarding RTCM over your telemetry link. No corrections = never more than a 3D fix.
- Check the fix type, not just “GPS OK”: in the MAVLink console run
gps status– fix type 5 = RTK float, 6 = RTK fixed. Float that never turns fixed usually means poor sky view, a weak telemetry link dropping RTCM packets, or a very long baseline. - Driver and port settings:
GPS_1_CONFIGon the right port,GPS_1_PROTOCOLmatching the receiver (u-blox, SBF for Septentrio, etc.), and baud rate high enough (115200 or auto). - Radiolink clones: some ship with ArduPilot-oriented firmware and port mapping. Flash the official PX4 firmware for your board target and re-check which physical port is GPS1.
If you post your GPS model and a log (gps status output), it’s easier to pinpoint.
Disclosure: I work with Eview GNSS. We wrote a longer checklist on choosing and wiring an RTK receiver for Pixhawk here, in case it helps: What GNSS Receiver Should Be Used with Pixhawk? | Eview GNSS
Hi Maskpro,
The previous reply covers the main RTK requirements well.
Since your GNSS receiver reportedly works with the Skystars H7HD, I would focus on identifying the difference between the two flight-controller configurations before changing hardware.
Could you share:
The exact Radiolink flight-controller model and PX4 firmware version.
The GNSS receiver model and firmware version.
The output of
gps statusfrom the PX4 MAVLink console. -
How RTCM corrections are delivered (QGroundControl base station, NTRIP or direct connection).
The current GPS port and protocol settings.
It would also help to confirm whether the receiver obtains a normal 3D fix but never reaches RTK Float/Fixed, or whether GPS detection itself fails.
These are different failure modes and require different troubleshooting steps.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
