I am testing latest master based on what had a chat about last meeting. The very first issue is I have no RC (13.2 is ok). My Pixhawk 5X is ok with RC. I am using Radiolink RS12 with SBUS by the way.
cc: @dagar
Some outputs are below:
nsh> dmesg
HW arch: PX4_FMU_V6C
HW type: V6C000000
HW version: 0x000
HW revision: 0x000
PX4 git-hash: 45b390b0bfe21fc591b36ec898f6fc0791fc4729
PX4 version: 1.13.0 80 (17629312)
OS: NuttX
OS version: Release 10.2.0 (167903487)
OS git-hash: 6bafcb22b7d62184fd1158c0b53c8dbd884275b8
Build datetime: Nov 19 2022 03:18:42
Build uri: localhost
Build variant: default
Toolchain: GNU GCC, 9.3.1 20200408 (release)
PX4GUID: 00060000000034373938303151040043002d
MCU: STM32H7[4|5]xxx, rev. V
INFO [param] selected parameter default file /fs/mtd_params
INFO [param] importing from '/fs/mtd_params'
WARN [parameters] ignoring unrecognised parameter 'PWM_AUX_OUT'
WARN [parameters] ignoring unrecognised parameter 'PWM_MAIN_OUT'
INFO [parameters] BSON document size 2567 bytes, decoded 2567 bytes (INT32:44, FLOAT:83)
INFO [param] selected parameter backup file /fs/microsd/parameters_backup.bson
Board architecture defaults: /etc/init.d/rc.board_arch_defaults
Board defaults: /etc/init.d/rc.board_defaults
Loading airframe: /etc/init.d/airframes/4015_holybro_s500
INFO [dataman] data manager file '/fs/microsd/dataman' size is 62560 bytes
rgbled_ncp5623c #0 on I2C bus 1 address 0x39
Board sensors: /etc/init.d/rc.board_sensors
bmi055_accel #0 on SPI bus 1 rotation 4
bmi055_gyro #0 on SPI bus 1 rotation 4
icm42688p #0 on SPI bus 1 rotation 6
ms5611 #0 on I2C bus 4 (external) address 0x77
ist8310 #0 on I2C bus 4 (external) address 0xC
ist8310 #1 on I2C bus 1 (external) address 0xE rotation 10
lightware_laser_i2c #0 on I2C bus 4 address 0x66 rotation 25
WARN [SPI_I2C] Already running on bus 1
ekf2 [533:237]
Starting Main GPS on /dev/ttyS0
Starting MAVLink on /dev/ttyS5
INFO [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS5 @ 57600B
INFO [logger] logger started (mode=all)
INFO [logger] Logging FIFO data: increasing task prio and logging rate
INFO [logger] Start file log (type: full)
INFO [uavcan] Node ID 1, bitrate 1000000
INFO [logger] [logger] /fs/microsd/log/2022-12-04/12_57_02.ulg
INFO [logger] Opened full log file: /fs/microsd/log/2022-12-04/12_57_02.ulg
NuttShell (NSH) NuttX-10.2.0
nsh> INFO [health_and_arming_checks] Preflight Fail: No manual control input
INFO [gps] u-blox firmware version: SPG 3.01
INFO [gps] u-blox protocol version: 18.00
WARN [health_and_arming_checks] Preflight: GPS fix too low
INFO [commander] Connection to ground station lost
INFO [commander] GCS connection regained
And also:
nsh> work_queue status
Work Queue: 10 threads RATE INTERVAL
|__ 1) wq:rate_ctrl
| |__ 1) control_allocator 665.4 Hz 1503 us
| |__ 2) mc_rate_control 665.4 Hz 1503 us
| |__ 3) pwm_out 665.4 Hz 1503 us
| \__ 4) vehicle_angular_velocity 665.4 Hz 1503 us
|__ 2) wq:SPI1
| |__ 1) bmi055_accel 677.4 Hz 1476 us
| |__ 2) bmi055_gyro 665.4 Hz 1503 us
| \__ 3) icm42688p 811.1 Hz 1233 us
|__ 3) wq:I2C1
| |__ 1) ist8310 46.8 Hz 21345 us
| \__ 2) rgbled_ncp5623c 9.9 Hz 100767 us
|__ 4) wq:I2C4
| |__ 1) ist8310 46.3 Hz 21620 us
| |__ 2) lightware_laser_i2c 19.8 Hz 50441 us
| \__ 3) ms5611 92.5 Hz 10810 us
|__ 5) wq:nav_and_controllers
| |__ 1) ekf2_selector 332.7 Hz 3006 us
| |__ 2) flight_mode_manager 50.0 Hz 19999 us
| |__ 3) land_detector 110.9 Hz 9017 us
| |__ 4) mc_att_control 221.8 Hz 4508 us
| |__ 5) mc_hover_thrust_estimator 110.9 Hz 9016 us
| |__ 6) mc_pos_control 110.9 Hz 9017 us
| |__ 7) sensors 221.8 Hz 4508 us
| |__ 8) vehicle_acceleration 225.8 Hz 4428 us
| |__ 9) vehicle_air_data 69.4 Hz 14413 us
| |__10) vehicle_gps_position 5.0 Hz 199946 us
| \__11) vehicle_magnetometer 46.3 Hz 21620 us
|__ 6) wq:INS0
| |__ 1) ekf2 221.8 Hz 4508 us
| |__ 2) ekf2 221.8 Hz 4508 us
| \__ 3) vehicle_imu 223.0 Hz 4485 us
|__ 7) wq:INS1
| |__ 1) ekf2 202.8 Hz 4932 us
| |__ 2) ekf2 202.8 Hz 4932 us
| \__ 3) vehicle_imu 221.3 Hz 4518 us
|__ 8) wq:hp_default
| |__ 1) battery_status 100.0 Hz 10000 us
| |__ 2) board_adc 100.0 Hz 10000 us (10000 us)
| |__ 3) gyro_fft 332.7 Hz 3006 us
| |__ 4) manual_control 5.0 Hz 200057 us
| |__ 5) mc_autotune_attitude_control 0.0 Hz 0 us
| |__ 6) rc_update 0.0 Hz 0 us
| \__ 7) tone_alarm 0.0 Hz 0 us
|__ 9) wq:uavcan
| |__ 1) uavcan 333.3 Hz 3000 us (3000 us)
| |__ 2) uavcan-actuators-esc 3.3 Hz 299659 us (300000 us)
| \__ 3) uavcan-actuators-servo 3.3 Hz 299661 us (300000 us)
\__ 10) wq:lp_default
|__ 1) gyro_calibration 50.0 Hz 19999 us (20000 us)
|__ 2) load_mon 2.0 Hz 499889 us (500000 us)
|__ 3) mag_bias_estimator 50.0 Hz 19998 us (20000 us)
\__ 4) send_event 30.0 Hz 33331 us (33333 us)
And a log in case needed:
https://review.px4.io/plot_app?log=8228c1dd-62ff-4b55-a6a4-4d799ce86f40
