saryee
August 20, 2016, 3:22pm
1
Hi there,
Now I’m trying to follow the examples of MAVROS offboard control example at http://dev.px4.io/ros-mavros-offboard.html and Ground Rover with Mavros at https://pixhawk.org/dev/ros/ground_rover .
The hardware is pixhawk and the firmware is latest px4 native stack.
I did like this:
roscore
roslaunch mavros px4.launch
rostopic echo /mavros/state
rostopic echo /mavros/imu/data
I can get he echo back from the pixhawk.
Then I changed to offboard mode and armed the vehicle.
header:
seq: 4764
stamp:
secs: 1471706320
nsecs: 371936367
frame_id: ‘’
connected: True
armed: True
guided: True
mode: OFFBOARD
Then I tried
rosparam set ros_yaw 0.5
rosparam set ros_throttle
But I couldn’t see any change on the main output.
Here is the waveform.
Could I get any suggestion on what to check?
Many thanks!
saryee
August 20, 2016, 3:27pm
2
Here is the parameter file.
Onboard parameters for vehicle 1
MAV ID COMPONENT ID PARAM NAME VALUE (FLOAT)
1 1 ATT_VIBE_THRESH 0.200000002980232239 9
1 1 BAT_A_PER_V 15.391030311584472656 9
1 1 BAT_CAPACITY -1.000000000000000000 9
1 1 BAT_CNT_V_CURR 0.000805664050858468 9
1 1 BAT_CNT_V_VOLT 0.000805664050858468 9
1 1 BAT_CRIT_THR 0.070000000298023224 9
1 1 BAT_LOW_THR 0.150000005960464478 9
1 1 BAT_N_CELLS 3 6
1 1 BAT_SOURCE 0 6
1 1 BAT_V_CHARGED 4.050000190734863281 9
1 1 BAT_V_DIV 10.177939414978027344 9
1 1 BAT_V_EMPTY 3.400000095367431641 9
1 1 BAT_V_LOAD_DROP 0.300000011920928955 9
1 1 BAT_V_OFFS_CURR 0.000000000000000000 9
1 1 BAT_V_SCALE_IO 10000 6
1 1 CAL_ACC0_ID 1246218 6
1 1 CAL_ACC0_XOFF 0.058046817779541016 9
1 1 CAL_ACC0_XSCALE 0.992938697338104248 9
1 1 CAL_ACC0_YOFF -0.027377605438232422 9
1 1 CAL_ACC0_YSCALE 1.005603194236755371 9
1 1 CAL_ACC0_ZOFF -0.391829013824462891 9
1 1 CAL_ACC0_ZSCALE 0.995418310165405273 9
1 1 CAL_ACC1_ID 1114634 6
1 1 CAL_ACC1_XOFF 1.036352634429931641 9
1 1 CAL_ACC1_XSCALE 1.002221584320068359 9
1 1 CAL_ACC1_YOFF 1.279943943023681641 9
1 1 CAL_ACC1_YSCALE 1.030997514724731445 9
1 1 CAL_ACC1_ZOFF 1.786358594894409180 9
1 1 CAL_ACC1_ZSCALE 1.003181099891662598 9
1 1 CAL_ACC_PRIME 1246218 6
1 1 CAL_BARO_PRIME 0 6
1 1 CAL_GYRO0_ID 2162688 6
1 1 CAL_GYRO0_XOFF -0.011748066172003746 9
1 1 CAL_GYRO0_XSCALE 1.000000000000000000 9
1 1 CAL_GYRO0_YOFF 0.024050502106547356 9
1 1 CAL_GYRO0_YSCALE 1.000000000000000000 9
1 1 CAL_GYRO0_ZOFF 0.009556505829095840 9
1 1 CAL_GYRO0_ZSCALE 1.000000000000000000 9
1 1 CAL_GYRO1_ID 2228490 6
1 1 CAL_GYRO1_XOFF 0.006698920857161283 9
1 1 CAL_GYRO1_XSCALE 1.000000000000000000 9
1 1 CAL_GYRO1_YOFF -0.005297438707202673 9
1 1 CAL_GYRO1_YSCALE 1.000000000000000000 9
1 1 CAL_GYRO1_ZOFF -0.022442327812314034 9
1 1 CAL_GYRO1_ZSCALE 1.000000000000000000 9
1 1 CAL_GYRO_PRIME 2162688 6
1 1 CAL_MAG0_ID 131594 6
1 1 CAL_MAG0_ROT -1 6
1 1 CAL_MAG0_XOFF -0.048616219311952591 9
1 1 CAL_MAG0_XSCALE 1.000000000000000000 9
1 1 CAL_MAG0_YOFF -0.072269201278686523 9
1 1 CAL_MAG0_YSCALE 1.000000000000000000 9
1 1 CAL_MAG0_ZOFF -0.060624413192272186 9
1 1 CAL_MAG0_ZSCALE 1.000000000000000000 9
1 1 CAL_MAG1_ID 0 6
1 1 CAL_MAG1_ROT -1 6
1 1 CAL_MAG2_ID 0 6
1 1 CAL_MAG2_ROT -1 6
1 1 CAL_MAG_PRIME 131594 6
1 1 CAL_MAG_SIDES 63 6
1 1 CBRK_AIRSPD_CHK 162128 6
1 1 CBRK_BUZZER 0 6
1 1 CBRK_ENGINEFAIL 284953 6
1 1 CBRK_FLIGHTTERM 121212 6
1 1 CBRK_GPSFAIL 0 6
1 1 CBRK_IO_SAFETY 22027 6
1 1 CBRK_SUPPLY_CHK 0 6
1 1 CBRK_USB_CHK 0 6
1 1 COM_ARM_WO_GPS 1 6
1 1 COM_AUTOS_PAR 1 6
1 1 COM_DISARM_LAND 0 6
1 1 COM_DL_LOSS_T 10 6
1 1 COM_DL_REG_T 0 6
1 1 COM_EF_C2T 5.000000000000000000 9
1 1 COM_EF_THROT 0.500000000000000000 9
1 1 COM_EF_TIME 10.000000000000000000 9
1 1 COM_FLTMODE1 -1 6
1 1 COM_FLTMODE2 -1 6
1 1 COM_FLTMODE3 -1 6
1 1 COM_FLTMODE4 -1 6
1 1 COM_FLTMODE5 -1 6
1 1 COM_FLTMODE6 -1 6
1 1 COM_HOME_H_T 5.000000000000000000 9
1 1 COM_HOME_V_T 10.000000000000000000 9
1 1 COM_LOW_BAT_ACT 0 6
1 1 COM_OBL_ACT 0 6
1 1 COM_OBL_RC_ACT 0 6
1 1 COM_OF_LOSS_T 0.000000000000000000 9
1 1 COM_RC_ARM_HYST 1000 6
1 1 COM_RC_IN_MODE 0 6
1 1 COM_RC_LOSS_T 0.500000000000000000 9
1 1 EKF2_ABIAS_INIT 0.200000002980232239 9
1 1 EKF2_ACC_B_NOISE 0.003000000026077032 9
1 1 EKF2_ACC_NOISE 0.349999994039535522 9
1 1 EKF2_AID_MASK 1 6
1 1 EKF2_ANGERR_INIT 0.100000001490116119 9
1 1 EKF2_ARSP_THR 0.000000000000000000 9
1 1 EKF2_ASP_DELAY 200.000000000000000000 9
1 1 EKF2_BARO_DELAY 0.000000000000000000 9
1 1 EKF2_BARO_GATE 5.000000000000000000 9
1 1 EKF2_BARO_NOISE 2.000000000000000000 9
1 1 EKF2_DECL_TYPE 7 6
1 1 EKF2_EAS_NOISE 1.399999976158142090 9
1 1 EKF2_EVA_NOISE 0.050000000745058060 9
1 1 EKF2_EVP_NOISE 0.050000000745058060 9
1 1 EKF2_EV_DELAY 175.000000000000000000 9
1 1 EKF2_EV_GATE 5.000000000000000000 9
1 1 EKF2_EV_POS_X 0.000000000000000000 9
1 1 EKF2_EV_POS_Y 0.000000000000000000 9
1 1 EKF2_EV_POS_Z 0.000000000000000000 9
1 1 EKF2_GBIAS_INIT 0.100000001490116119 9
1 1 EKF2_GPS_CHECK 21 6
1 1 EKF2_GPS_DELAY 200.000000000000000000 9
1 1 EKF2_GPS_POS_X 0.000000000000000000 9
1 1 EKF2_GPS_POS_Y 0.000000000000000000 9
1 1 EKF2_GPS_POS_Z 0.000000000000000000 9
1 1 EKF2_GPS_P_GATE 5.000000000000000000 9
1 1 EKF2_GPS_P_NOISE 0.500000000000000000 9
1 1 EKF2_GPS_V_GATE 5.000000000000000000 9
1 1 EKF2_GPS_V_NOISE 0.500000000000000000 9
1 1 EKF2_GYR_B_NOISE 0.001000000047497451 9
1 1 EKF2_GYR_NOISE 0.014999999664723873 9
1 1 EKF2_HDG_GATE 2.599999904632568359 9
1 1 EKF2_HEAD_NOISE 0.300000011920928955 9
1 1 EKF2_HGT_MODE 0 6
1 1 EKF2_IMU_POS_X 0.000000000000000000 9
1 1 EKF2_IMU_POS_Y 0.000000000000000000 9
1 1 EKF2_IMU_POS_Z 0.000000000000000000 9
1 1 EKF2_MAG_B_NOISE 0.000099999997473788 9
1 1 EKF2_MAG_DECL 0.000000000000000000 9
1 1 EKF2_MAG_DELAY 0.000000000000000000 9
1 1 EKF2_MAG_E_NOISE 0.001000000047497451 9
1 1 EKF2_MAG_GATE 3.000000000000000000 9
1 1 EKF2_MAG_NOISE 0.050000000745058060 9
1 1 EKF2_MAG_TYPE 0 6
1 1 EKF2_MIN_RNG 0.100000001490116119 9
1 1 EKF2_NOAID_NOISE 10.000000000000000000 9
1 1 EKF2_OF_DELAY 5.000000000000000000 9
1 1 EKF2_OF_GATE 3.000000000000000000 9
1 1 EKF2_OF_N_MAX 0.500000000000000000 9
1 1 EKF2_OF_N_MIN 0.150000005960464478 9
1 1 EKF2_OF_POS_X 0.000000000000000000 9
1 1 EKF2_OF_POS_Y 0.000000000000000000 9
1 1 EKF2_OF_POS_Z 0.000000000000000000 9
1 1 EKF2_OF_QMIN 1 6
1 1 EKF2_OF_RMAX 2.500000000000000000 9
1 1 EKF2_REC_RPL 0 6
1 1 EKF2_REQ_EPH 5.000000000000000000 9
1 1 EKF2_REQ_EPV 8.000000000000000000 9
1 1 EKF2_REQ_GDOP 2.500000000000000000 9
1 1 EKF2_REQ_HDRIFT 0.300000011920928955 9
1 1 EKF2_REQ_NSATS 6 6
1 1 EKF2_REQ_SACC 1.000000000000000000 9
1 1 EKF2_REQ_VDRIFT 0.500000000000000000 9
1 1 EKF2_RNG_DELAY 5.000000000000000000 9
1 1 EKF2_RNG_GATE 5.000000000000000000 9
1 1 EKF2_RNG_NOISE 0.100000001490116119 9
1 1 EKF2_RNG_POS_X 0.000000000000000000 9
1 1 EKF2_RNG_POS_Y 0.000000000000000000 9
1 1 EKF2_RNG_POS_Z 0.000000000000000000 9
1 1 EKF2_TAS_GATE 3.000000000000000000 9
1 1 EKF2_TAU_POS 0.250000000000000000 9
1 1 EKF2_TAU_VEL 0.500000000000000000 9
1 1 EKF2_TERR_GRAD 0.500000000000000000 9
1 1 EKF2_TERR_NOISE 5.000000000000000000 9
1 1 EKF2_WIND_NOISE 0.100000001490116119 9
1 1 FW_AIRSPD_TRIM 15.000000000000000000 9
1 1 FW_ARSP_MODE 0 6
1 1 FW_CLMBOUT_DIFF 10.000000000000000000 9
1 1 FW_MAN_P_SC 1.000000000000000000 9
1 1 FW_MAN_R_SC 1.000000000000000000 9
1 1 FW_MAN_Y_SC 1.000000000000000000 9
1 1 FW_THR_CRUISE 0.600000023841857910 9
1 1 GF_ACTION 1 6
1 1 GF_ALTMODE 0 6
1 1 GF_COUNT -1 6
1 1 GF_MAX_HOR_DIST -1 6
1 1 GF_MAX_VER_DIST -1 6
1 1 GF_SOURCE 0 6
1 1 GPS_DUMP_COMM 0 6
1 1 INAV_LIDAR_ERR 0.200000002980232239 9
1 1 MAV_BROADCAST 0 6
1 1 MAV_COMP_ID 1 6
1 1 MAV_FWDEXTSP 1 6
1 1 MAV_PROTO_VER 1 6
1 1 MAV_RADIO_ID 0 6
1 1 MAV_SYS_ID 1 6
1 1 MAV_TEST_PAR 1 6
1 1 MAV_TYPE 10 6
1 1 MAV_USEHILGPS 0 6
1 1 MC_YAWRAUTO_MAX 45.000000000000000000 9
1 1 MIS_ALTMODE 1 6
1 1 MIS_DIST_1WP 900.000000000000000000 9
1 1 MIS_LTRMIN_ALT 1.200000047683715820 9
1 1 MIS_ONBOARD_EN 1 6
1 1 MIS_TAKEOFF_ALT 10.000000000000000000 9
1 1 MIS_YAWMODE 1 6
1 1 MIS_YAW_ERR 12.000000000000000000 9
1 1 MIS_YAW_TMT -1.000000000000000000 9
1 1 MPC_XY_CRUISE 5.000000000000000000 9
1 1 NAV_ACC_RAD 10.000000000000000000 9
1 1 NAV_AH_ALT 600.000000000000000000 9
1 1 NAV_AH_LAT -265847810 6
1 1 NAV_AH_LON 1518423250 6
1 1 NAV_DLL_ACT 0 6
1 1 NAV_DLL_AH_T 120.000000000000000000 9
1 1 NAV_DLL_CHSK 0 6
1 1 NAV_DLL_CH_ALT 600.000000000000000000 9
1 1 NAV_DLL_CH_LAT -266072120 6
1 1 NAV_DLL_CH_LON 1518453890 6
1 1 NAV_DLL_CH_T 120.000000000000000000 9
1 1 NAV_DLL_N 2 6
1 1 NAV_FT_DST 8.000000000000000000 9
1 1 NAV_FT_FS 1 6
1 1 NAV_FT_RS 0.500000000000000000 9
1 1 NAV_FW_ALT_RAD 10.000000000000000000 9
1 1 NAV_GPSF_LT 30.000000000000000000 9
1 1 NAV_GPSF_P 0.000000000000000000 9
1 1 NAV_GPSF_R 15.000000000000000000 9
1 1 NAV_GPSF_TR 0.699999988079071045 9
1 1 NAV_LOITER_RAD 50.000000000000000000 9
1 1 NAV_MC_ALT_RAD 3.000000000000000000 9
1 1 NAV_MIN_FT_HT 8.000000000000000000 9
1 1 NAV_RCL_ACT 2 6
1 1 NAV_RCL_LT 120.000000000000000000 9
1 1 PWM_AUX_DISARMED 1000 6
1 1 PWM_AUX_MAX 2000 6
1 1 PWM_AUX_MIN 1000 6
1 1 PWM_DISARMED 0 6
1 1 PWM_MAIN_REV1 0 6
1 1 PWM_MAIN_REV2 0 6
1 1 PWM_MAIN_REV3 0 6
1 1 PWM_MAIN_REV4 0 6
1 1 PWM_MAIN_REV5 0 6
1 1 PWM_MAIN_REV6 0 6
1 1 PWM_MAIN_REV7 0 6
1 1 PWM_MAIN_REV8 0 6
1 1 PWM_MAX 2000 6
1 1 PWM_MIN 1000 6
1 1 PWM_SBUS_MODE 0 6
1 1 RC10_DZ 0.000000000000000000 9
1 1 RC10_MAX 2000.000000000000000000 9
1 1 RC10_MIN 1000.000000000000000000 9
1 1 RC10_REV 1.000000000000000000 9
1 1 RC10_TRIM 1500.000000000000000000 9
1 1 RC11_DZ 0.000000000000000000 9
1 1 RC11_MAX 2000.000000000000000000 9
1 1 RC11_MIN 1000.000000000000000000 9
1 1 RC11_REV 1.000000000000000000 9
1 1 RC11_TRIM 1500.000000000000000000 9
1 1 RC12_DZ 0.000000000000000000 9
1 1 RC12_MAX 2000.000000000000000000 9
1 1 RC12_MIN 1000.000000000000000000 9
1 1 RC12_REV 1.000000000000000000 9
1 1 RC12_TRIM 1500.000000000000000000 9
1 1 RC13_DZ 0.000000000000000000 9
1 1 RC13_MAX 2000.000000000000000000 9
1 1 RC13_MIN 1000.000000000000000000 9
1 1 RC13_REV 1.000000000000000000 9
1 1 RC13_TRIM 1500.000000000000000000 9
1 1 RC14_DZ 0.000000000000000000 9
1 1 RC14_MAX 2000.000000000000000000 9
1 1 RC14_MIN 1000.000000000000000000 9
1 1 RC14_REV 1.000000000000000000 9
1 1 RC14_TRIM 1500.000000000000000000 9
1 1 RC15_DZ 0.000000000000000000 9
1 1 RC15_MAX 2000.000000000000000000 9
1 1 RC15_MIN 1000.000000000000000000 9
1 1 RC15_REV 1.000000000000000000 9
1 1 RC15_TRIM 1500.000000000000000000 9
1 1 RC16_DZ 0.000000000000000000 9
1 1 RC16_MAX 2000.000000000000000000 9
1 1 RC16_MIN 1000.000000000000000000 9
1 1 RC16_REV 1.000000000000000000 9
1 1 RC16_TRIM 1500.000000000000000000 9
1 1 RC17_DZ 0.000000000000000000 9
1 1 RC17_MAX 2000.000000000000000000 9
1 1 RC17_MIN 1000.000000000000000000 9
1 1 RC17_REV 1.000000000000000000 9
1 1 RC17_TRIM 1500.000000000000000000 9
1 1 RC18_DZ 0.000000000000000000 9
1 1 RC18_MAX 2000.000000000000000000 9
1 1 RC18_MIN 1000.000000000000000000 9
1 1 RC18_REV 1.000000000000000000 9
1 1 RC18_TRIM 1500.000000000000000000 9
1 1 RC1_DZ 10.000000000000000000 9
1 1 RC1_MAX 2006.000000000000000000 9
1 1 RC1_MIN 982.000000000000000000 9
1 1 RC1_REV 1.000000000000000000 9
1 1 RC1_TRIM 1488.000000000000000000 9
1 1 RC2_DZ 10.000000000000000000 9
1 1 RC2_MAX 1998.000000000000000000 9
1 1 RC2_MIN 982.000000000000000000 9
1 1 RC2_REV 1.000000000000000000 9
1 1 RC2_TRIM 1485.000000000000000000 9
1 1 RC3_DZ 10.000000000000000000 9
1 1 RC3_MAX 2006.000000000000000000 9
1 1 RC3_MIN 982.000000000000000000 9
1 1 RC3_REV 1.000000000000000000 9
1 1 RC3_TRIM 982.000000000000000000 9
1 1 RC4_DZ 10.000000000000000000 9
1 1 RC4_MAX 2006.000000000000000000 9
1 1 RC4_MIN 982.000000000000000000 9
1 1 RC4_REV 1.000000000000000000 9
1 1 RC4_TRIM 1492.000000000000000000 9
1 1 RC5_DZ 10.000000000000000000 9
1 1 RC5_MAX 2000.000000000000000000 9
1 1 RC5_MIN 1000.000000000000000000 9
1 1 RC5_REV 1.000000000000000000 9
1 1 RC5_TRIM 1500.000000000000000000 9
1 1 RC6_DZ 10.000000000000000000 9
1 1 RC6_MAX 2000.000000000000000000 9
1 1 RC6_MIN 1000.000000000000000000 9
1 1 RC6_REV 1.000000000000000000 9
1 1 RC6_TRIM 1500.000000000000000000 9
1 1 RC7_DZ 10.000000000000000000 9
1 1 RC7_MAX 2000.000000000000000000 9
1 1 RC7_MIN 1000.000000000000000000 9
1 1 RC7_REV 1.000000000000000000 9
1 1 RC7_TRIM 1500.000000000000000000 9
1 1 RC8_DZ 10.000000000000000000 9
1 1 RC8_MAX 2000.000000000000000000 9
1 1 RC8_MIN 1000.000000000000000000 9
1 1 RC8_REV 1.000000000000000000 9
1 1 RC8_TRIM 1500.000000000000000000 9
1 1 RC9_DZ 0.000000000000000000 9
1 1 RC9_MAX 2000.000000000000000000 9
1 1 RC9_MIN 1000.000000000000000000 9
1 1 RC9_REV 1.000000000000000000 9
1 1 RC9_TRIM 1500.000000000000000000 9
1 1 RC_ACRO_TH 0.261045426130294800 9
1 1 RC_ASSIST_TH 0.359566718339920044 9
1 1 RC_AUTO_TH 0.680300235748291016 9
1 1 RC_CHAN_CNT 18 6
1 1 RC_DSM_BIND -1 6
1 1 RC_FAILS_THR 0 6
1 1 RC_KILLSWITCH_TH 0.250000000000000000 9
1 1 RC_LOITER_TH 0.940626561641693115 9
1 1 RC_MAP_ACRO_SW 5 6
1 1 RC_MAP_AUX1 0 6
1 1 RC_MAP_AUX2 0 6
1 1 RC_MAP_AUX3 0 6
1 1 RC_MAP_AUX4 0 6
1 1 RC_MAP_AUX5 0 6
1 1 RC_MAP_FAILSAFE 0 6
1 1 RC_MAP_FLAPS 0 6
1 1 RC_MAP_FLTMODE 0 6
1 1 RC_MAP_KILL_SW 0 6
1 1 RC_MAP_LOITER_SW 5 6
1 1 RC_MAP_MODE_SW 5 6
1 1 RC_MAP_OFFB_SW 0 6
1 1 RC_MAP_PARAM1 0 6
1 1 RC_MAP_PARAM2 0 6
1 1 RC_MAP_PARAM3 0 6
1 1 RC_MAP_PITCH 2 6
1 1 RC_MAP_POSCTL_SW 5 6
1 1 RC_MAP_RATT_SW 0 6
1 1 RC_MAP_RETURN_SW 0 6
1 1 RC_MAP_ROLL 1 6
1 1 RC_MAP_THROTTLE 3 6
1 1 RC_MAP_TRANS_SW 0 6
1 1 RC_MAP_YAW 4 6
1 1 RC_OFFB_TH 0.000000000000000000 9
1 1 RC_POSCTL_TH 0.560204982757568359 9
1 1 RC_RATT_TH 0.500000000000000000 9
1 1 RC_RETURN_TH 0.000000000000000000 9
1 1 RC_RSSI_PWM_CHAN 0 6
1 1 RC_RSSI_PWM_MAX 1000 6
1 1 RC_RSSI_PWM_MIN 2000 6
1 1 RC_TH_USER 1 6
1 1 RC_TRANS_TH 0.250000000000000000 9
1 1 RTL_DESCEND_ALT 30.000000000000000000 9
1 1 RTL_LAND_DELAY -1.000000000000000000 9
1 1 RTL_MIN_DIST 5.000000000000000000 9
1 1 RTL_RETURN_ALT 60.000000000000000000 9
1 1 SDLOG_EXT -1 6
1 1 SDLOG_GPSTIME 1 6
1 1 SDLOG_PRIO_BOOST 2 6
1 1 SDLOG_RATE -1 6
1 1 SENS_BARO_QNH 1013.250000000000000000 9
1 1 SENS_BOARD_ROT 0 6
1 1 SENS_BOARD_X_OFF -0.773275911808013916 9
1 1 SENS_BOARD_Y_OFF -0.617106854915618896 9
1 1 SENS_BOARD_Z_OFF 0.000000000000000000 9
1 1 SENS_DPRES_ANSC 0.000000000000000000 9
1 1 SENS_DPRES_OFF 0.000000000000000000 9
1 1 SENS_EN_LL40LS 0 6
1 1 SENS_EN_MB12XX 0 6
1 1 SENS_EN_SF0X 0 6
1 1 SYS_AUTOCONFIG 0 6
1 1 SYS_AUTOSTART 50001 6
1 1 SYS_COMPANION 57600 6
1 1 SYS_LOGGER 0 6
1 1 SYS_MC_EST_GROUP 1 6
1 1 SYS_PARAM_VER 1 6
1 1 SYS_RESTART_TYPE 0 6
1 1 SYS_USE_IO 1 6
1 1 TRIG_MODE 0 6
1 1 TRIM_PITCH 0.000000000000000000 9
1 1 TRIM_ROLL 0.000000000000000000 9
1 1 TRIM_YAW 0.000000000000000000 9
1 1 UAVCAN_ENABLE 0 6
1 1 VT_NAV_FORCE_VT 1 6
1 1 VT_WV_LND_EN 0 6
1 1 VT_WV_LTR_EN 0 6
Thanks!
saryee
August 22, 2016, 3:21pm
3
I checked the pwm and mixer in the shell.
What I ran “nsh> pwm rate -c 1234 -r 100” and “nsh> pwm rate -c 1234 -r 50”, I can see the pwm rate changing to 100 Hz then back to 50 Hz.
Which node polls that parameter change?
Note in ROS1 parameters are stored in master and nodes can’t subscribe to param change, only inefficient poll loop.
saryee
August 22, 2016, 5:13pm
5
Thank you very much for your reply! I’ll check as you suggested.
ealdaz
April 10, 2017, 4:49pm
6
Not sure if you’re still stuck with this, but I can’t see that you’re running the node that is publishing the mavros/actuator_control topic
BTW I think the example is old, in order to get it compiled I had to do a number of changes:
I had to replace mavros by mavros_msgs and the message actuator_controls by actuator_control.
The 3 modified lines are below:
#include <mavros_msgs/ActuatorControl.h>
ros::Publisher actuator_controls_pub = nh.advertise<mavros_msgs::ActuatorControl>("/mavros/actuator_control", 1000)
mavros_msgs::ActuatorControl actuator_control_msg;
Seemed to work fine for me in SITL
