Can I switch to offboard mode after the drone takes off by joystick control? How to use offboard mode by mcu?
If I want to use mcu to control the FC under offboard mode, and mcu sends mavlink message to FC by uart port, how do I know whether FC receives the message successfully?
Initially, it is not possible to switch to offboard mode after taking off because it requires receiving an offboard signal. The vast majority of offboard examples (if not all) already have their own arming command in the code. In my experience, an external controller (such as a Raspberry Pi) is needed to send the offboard signal. It is also important that the offboard signal you send must be greater than 2Hz.
I have had a few problems with the offboard mode and have achieved some results although I am still struggling with it .
I’ll leave you my discussions about offboard mode and similar things to see if they help you in any way:
I don’t know if I’ve helped you at all, but I hope I’ve helped you! I hope you have a nice day and if you need anything don’t hesitate to ask in this forum . If I have explained myself wrong (which is possible because I am translating everything ) or I have not solved your question let me know and maybe someone else will be able to help you more than me.
I am doing the autonomous drone without gps. Can I be able to do with ROS1 using offboard mode. Which sensors are preferable to achieve the autonomous. I am using Raspberry Pi 4b with Ubuntu 20.04.
