Hey,
I am trying to send the actuator commands directly over /mavros/actuator_control in offboard mode but when I send the commands the Px4 is forced to switch back to position control mode and doesn’t come back to offboard mode and the plane doesnt fly.
These are the steps I followed:
- disable lockstep simulation
- started px4 sitl:
make px4_sitl gazebo_plane
- started mavros:
roslaunch mavros px4.launch fcu_url:="udp://:14540@127.0.0.1:14557"
- ran this code:
#include <ros/ros.h>
#include <geometry_msgs/PoseStamped.h>
#include <mavros_msgs/CommandBool.h>
#include <mavros_msgs/SetMode.h>
#include <mavros_msgs/State.h>
#include <mavros_msgs/ActuatorControl.h>
mavros_msgs::State current_state;
void state_cb(const mavros_msgs::State::ConstPtr& msg){
current_state = *msg;
int main(int argc, char **argv)
ros::init(argc, argv, "offb_node");
ros::NodeHandle nh;
ros::Subscriber state_sub = nh.subscribe<mavros_msgs::State>
("mavros/state", 10, state_cb);
// ros::Publisher local_pos_pub = nh.advertise<geometry_msgs::PoseStamped>
// ("mavros/setpoint_position/local", 10);
ros::Publisher act_pub = nh.advertise<mavros_msgs::ActuatorControl>
("mavros/actuator_control", 10);
ros::ServiceClient arming_client = nh.serviceClient<mavros_msgs::CommandBool>
("mavros/cmd/arming");
ros::ServiceClient set_mode_client = nh.serviceClient<mavros_msgs::SetMode>
("mavros/set_mode");
//the setpoint publishing rate MUST be faster than 2Hz
ros::Rate rate(50.0);
// wait for FCU connection
while(ros::ok() && !current_state.connected){
ros::spinOnce();
rate.sleep();
geometry_msgs::PoseStamped pose;
pose.pose.position.x = 0;
pose.pose.position.y = 20;
pose.pose.position.z = 20;
mavros_msgs::ActuatorControl setpoint;
setpoint.header.stamp = ros::Time::now();
setpoint.group_mix = 0;
setpoint.controls[0] = 0;
setpoint.controls[1] = 0;
setpoint.controls[2] = 0;
setpoint.controls[3] = 1;
setpoint.controls[4] = 0;
setpoint.controls[5] = 0;
setpoint.controls[6] = 0;
setpoint.controls[7] = 0;
//send a few setpoints before starting
for(int i = 20; ros::ok() && i > 0; --i){
// local_pos_pub.publish(pose);
act_pub.publish(setpoint);
ros::spinOnce();
rate.sleep();
mavros_msgs::SetMode offb_set_mode;
offb_set_mode.request.custom_mode = "OFFBOARD";
mavros_msgs::CommandBool arm_cmd;
arm_cmd.request.value = true;
ros::Time last_request = ros::Time::now();
ros::Time last_request_arm = ros::Time::now();
while(ros::ok()){
// act_pub.publish(setpoint);
if( current_state.mode != "OFFBOARD" &&
(ros::Time::now() - last_request > ros::Duration(0.5))){
if( set_mode_client.call(offb_set_mode) &&
offb_set_mode.response.mode_sent){
ROS_INFO("Offboard enabled");
if( !current_state.armed &&
(ros::Time::now() - last_request_arm > ros::Duration(1))){
if( arming_client.call(arm_cmd) &&
arm_cmd.response.success){
ROS_INFO("Vehicle armed");
ros::spinOnce();
rate.sleep();
return 0;
Not sure what I am doing wrong. Any help will be appreciated.
Thanks in advance
