I am facing a challenge in building a custom SITL airframe in PX4 and could use some expert advice.
Issue Summary:
I created a custom airframe script 22001_none_plane in the init.d-posix directory, essentially duplicating the standard plane script from init.d. Despite correctly adding it to the CMakeLists.txt in the same directory and performing both make distclean and make clean, I am encountering a build error.
Specifics of the Problem:
When running the build command:
make px4_sitl none_plane
I receive the error:
ninja: error: unknown target 'none_plane'
make: *** [Makefile:232: px4_sitl] Error 1
Attempts to Resolve:
- Ensured the script
22001_none_plane is accurately named and located in ROMFS/px4fmu_common/init.d-posix/airframes.
- Added the script reference to
CMakeLists.txt in the init.d-posix/airframes directory.
- Tried various IDs and names, even replicating another model (like
none_iris) with a new name and ID.
- Conducted thorough
make distclean and make clean operations.
Despite these efforts, the issue persists, and the build system doesn’t recognize the new target. I am using PX4 on WSL (Windows Subsystem for Linux) and have checked for common file format issues (line endings, permissions).
Request for Guidance:
- Is there a step I’m missing or a common pitfall in this process?
- Could this issue be related to a specific aspect of PX4’s build system, particularly in the context of WSL?
- Has anyone encountered a similar challenge and found a workaround?
I appreciate any insights or suggestions you can provide. It’s a roadblock in my project, and any help to move forward would be invaluable.
Thank you in advance for your assistance!
Shouldn’t it be called 22001_plane? I think none is for the choice of simulator to start.
I used to think like that but it seems we already have a none_iris in the init.posix folder. That’s why I am confused!
I tested adding 22001_plane and using make px4_sitl plane and make px4_sitl none_plane
and also tested with 22001_none_plane …
That is why I thought either I was missing a step or a bug within the WSL environment…
Hello
After some investigation, I found that the handling of airframe names in PX4 has changed, especially from version 1.15 alpha onwards. In previous versions, we used to define a ‘plane’ airframe and then apply ‘none_plane’ for additional setups. However, the latest version requires each simulator definition to be specified separately.
To resolve this, I defined a ‘none_plane’ airframe and made necessary changes in the src/modules/simulation/simulator_mavlink/CMakeLists.txt file. Here’s the essential addition I made:
# none_plane (legacy compatibility launch helper)
add_custom_target(none_plane
COMMAND ${CMAKE_COMMAND} -E env PX4_SYS_AUTOSTART=22001 $<TARGET_FILE:px4>
WORKING_DIRECTORY ${SITL_WORKING_DIR}
USES_TERMINAL
DEPENDS
px4
${PX4_SOURCE_DIR}/ROMFS/px4fmu_common/init.d-posix/airframes/22001_none_plane
COMMENT "launching px4 none_plane (SYS_AUTOSTART=22001)"
Furthermore, it’s crucial to include ‘none_plane’ in the cmakelists in the init.d-posix/airframes/ directory just like before. This approach solved the build error I was facing. If you’re dealing with a similar issue, I hope this solution helps you as well.
and this is my definition of airframe
#!/bin/sh
# @name Generic Standard Plane SITL for custom Simulator
# @type Standard Plane
# @class Plane
# @author alireza787b
. ${R}etc/init.d/rc.fw_defaults
param set-default CA_AIRFRAME 1
param set-default CA_ROTOR_COUNT 1
param set-default CA_ROTOR0_PX 0.3
param set-default CA_SV_CS_COUNT 4
param set-default CA_SV_CS0_TYPE 1
param set-default CA_SV_CS0_TRQ_R -0.5
param set-default CA_SV_CS1_TRQ_R 0.5
param set-default CA_SV_CS1_TYPE 2
param set-default CA_SV_CS2_TRQ_P 1.0
param set-default CA_SV_CS2_TYPE 3
param set-default CA_SV_CS3_TRQ_Y 1.0
param set-default CA_SV_CS3_TYPE 4
param set-default SENS_EN_GPSSIM 1
param set-default SENS_EN_BAROSIM 1
param set-default SENS_EN_MAGSIM 1
param set-default SENS_EN_ARSPDSIM 1
# disable some checks to allow to fly:
# - with usb
param set-default CBRK_USB_CHK 197848
# - without real battery
param set-default CBRK_SUPPLY_CHK 894281
# - without safety switch
param set-default CBRK_IO_SAFETY 22027
# - without Airspeed Sensor
param set-default CBRK_AIRSPD_CHK 1612128
