New vehicle type: Airship
Our team has created a new vehicle type - an airship that can also be simulated in Gazebo. We would like to integrate it with the PX4 Firmware stack. As an initial step, we’re opening a discussion here before a pull request is opened.
https://github.com/flycloudline/Firmware brings the cloudship airframe, mixer, manual flying and links to https://github.com/flycloudline/sitl_gazebo_airship, which includes a twin-prop stabilator, tail rotor, fins, gondola and payload, with aerodynamics and buoyancy applied.
Currently, it is based off v1.10.1. I believe the next step is to port to master before a pull request can be made?
Thank you for the great work on PX4!
@drobin That’s really cool - I want one :-).
So yes, you need to port to master to make a PR. You obviously have a good handle on what needs to be done, but in case you need more inspiration, have you see this doc: http://dev.px4.io/master/en/airframes/adding_a_new_frame.html
We’ll get your PR reviewed once it is in. Probably by @Jaeyoung-Lim - he’s the go-to person for anything to do with gazebo models and integration. Jae, anything you care to add?
Once you have a PR I’ll chase you up about documentation too :slight_smile:
Thanks, have a look at https://dev.px4.io/master/en/simulation/gazebo_vehicles.html#airship!
