New Pixhawk Cube Orange+ hardware incompatible with PX4 v1.14.x?
Hi all,
I’m seeing a repeatable issue on newer Pixhawk Cube Orange+ boards where PX4 v1.14.x breaks RC/IO, but PX4 v1.15+ works fine.
  • Older Cube Orange+ (bought before ~Summer 2025): run PX4 1.14.0 / 1.14.3 with no problems (RC, PWM, GPS, TFmini LiDAR all OK).
  • Newer Cube Orange+ (bought Aug 2025):
    • Stock 1.15 / 1.16 / 1.17 → everything works.
    • Stock 1.14.0 / 1.14.3 and MATLAB-generated 1.14.0/1.14.3 →
      • Error tune on boot
      • No RC input (no RC_CHANNELS / RC_CHANNELS_RAW in MAVLink Inspector)
      • No DISTANCE_SENSOR from TFmini
      • PWM_MAIN 1–8 effectively disabled and PWM_MAIN_TIM* params missing
ver all is identical between the “good” and “bad” cubes (same CUBEPILOT_CUBEORANGEPLUS, MCU rev, bootloader, etc.), so PX4 thinks they are the same board.
Why I’m on 1.14.x: my lab uses the MATLAB UAV Toolbox PX4 Support Package, which is currently pinned to PX4 1.14.x. The exact same MATLAB-generated 1.14.x firmware still works on my older Cube Orange+ boards, but fails on the newer ones in the same way as stock 1.14.x.
My working guess is that there’s a new Cube Orange+ hardware/IO revision that PX4 1.14.x doesn’t fully support, while 1.15+ does.
Questions:
  • Has anyone else seen this with recent Cube Orange+ batches on 1.14.0/1.14.3?
  • Is there any known explanation or doc for hardware changes that affect 1.14.x?
  • Is the realistic guidance simply “don’t use 1.14.x on new Orange+; use 1.15+”, or is there a known backport/workaround?
Happy to share full ver all, param dumps, and logs if useful.
Thanks,
-A
We are seeing the same thing, but no solutions yet.
Hey,
Maybe the note here is relevant? So apparently, Nuttx update was required for these issues to be resolved since I am seeing they all look like power issues from what you mentioned above.
I reached out to MathWorks and received some very useful information:
  1. Launch & run the hardware setup screens from MATLAB and in the “Test Connection” screen, upload the firmware on the Cube Orange+ board. This would upload v1.14.3 now, but that’s fine.
  2. Close hardware setup screen in MATLAB.
  3. Launch QGroundControl (QGC). Wait for it connect to the newer Cube Orange+.
  4. In QGC, navigate to MAVLink Console.
  5. In the MAVLink console, run the command “bl_update /etc/extras/cubepilot_cubeorangeplus_bootloader.bin
  6. You would see the below expected output when the bootloader is updated correctly.
nsh> bl_update /etc/extras/cubepilot_cubeorangeplus_bootloader.bin
INFO [bl_update] image validated, erasing bootloader…
INFO [bl_update] flashing…
INFO [bl_update] verifying…
INFO [bl_update] bootloader update complete
Reboot the Cube Orange+ hardware.
Based on our preliminary testing, this has fixed the issue. I confirmed this also works for stock v1.14.0.
