I am using px4fmu V1 hardware and recently I changed to the new firmware repo. The hardware was bought 2 years ago. The problem is, after I uploaded the firmware (make upload px4fmu-v1_default) to the board, I found the system instantly hang there once I type “mpu6000 start” in the nsh terminal. Also I have my own customized board using MPU9250, with the same problem. I looked into the code and it seems that the spi transfer function caused the system crash.
The compiler I am using is cmake-3.4.3 and arm-none-eabi-gcc 5.4.1. Hope anyone can help me out of the problem.
Anyone met the same problem? I am using the PX4FMU v1.7 and the most recent code cloned from pixhawk github repo and cannot figure out what is the problem…
[boot] Enabling IN12/13 instead of SPI2
sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
nsh: mount: mount failed: No such device
nsh: mkfatfs: mkfatfs failed: I/O error
WARN [param] selected parameter default file /fs/mtd_params
WARN [rgbled] no RGB led on bus #3
WARN [blinkm] I2C init failed
WARN [blinkm] init failed
PX4IO_i2c on I2C bus 2 at 0x1a (bus: 100 KHz, max: 400 KHz)
WARN [px4io] CRCs match
WARN [dataman] Could not open data manager file /fs/microsd/dataman
ERROR [dataman] dataman start failed
INFO [ver] match: PX4FMU_V1
MS5611_I2C on I2C bus 2 at 0x76 (bus: 100 KHz, max: 400 KHz)
WARN [ms5611] no device on bus 2
MPU6000 on SPI bus 1 at 3 (1000 KHz)
L3G
