I have Pix32 v5, while trying to run motor test in Mission Planner, the motors are spinning in a random direction instead of CCW/CW.
Anyone knows what`s the problem?
Thank`s
Thank`s
If you’re using Mission Planner, you’re likely using ArduPilot, so I would ask over in https://discuss.ardupilot.org.
Also, what do you mean by random direction? How it spins depends on your wiring of the ESC to the motor and not the software (normally, in some cases it is different).
Correct. With dshot, you can reverse it in software, otherwise it’s easiest to just swap any two of the three wires going from the ESC to the motor.
