Hello all,
I am running
Plane, PX4 1.10.0 in the Gazebo sim
I am trying to get the plane to take off using this code in python. I got it to work with PX4 1.9.2 but now that I have updated to PX4 1.10 I get “Mission Rejected: landing pattern required”
Is there a simple way to omit this requirement? I dont care about the landing part, I just want to fly and let gravity do the rest in the sim.
@File DroneKitPX4.py
Example usage of DroneKit with PX4
@author Sander Smeets sander@droneslab.com
Code partly based on DroneKit © Copyright 2015-2016, 3D Robotics.
Import DroneKit-Python
from dronekit import connect, Command, LocationGlobal
from pymavlink import mavutil
import time, sys, argparse, math
Settings
connection_string = ‘127.0.0.1:14540’
#connection_string = ‘/dev/ttyUSB0’
#MAV_MODE_AUTO = mavutil.PX4_CUSTOM_MAIN_MODE_ALTCTL
MAV_MODE_AUTO = 1
#https://github.com/PX4/Firmware/blob/master/Tools/mavlink_px4.py
Parse connection argument
parser = argparse.ArgumentParser()
parser.add_argument("-c", “–connect”, help=“connection string”)
args = parser.parse_args()
if args.connect:
connection_string = args.connect
Init
Connect to the Vehicle
print “Connecting”
vehicle = connect(connection_string, wait_ready=False, baud=921600)
def PX4setMode(mavMode):
confirmation = 0
mode = 1
custom_mode = mavMode
custom_submodule = 0
vehicle._master.mav.command_long_send(vehicle._master.target_system, vehicle._master.target_component,
mavutil.mavlink.MAV_CMD_DO_SET_MODE,
confirmation,
mode,
custom_mode,
custom_submodule, 0, 0, 0, 0)
def get_location_offset_meters(original_location, dNorth, dEast, alt):
Returns a LocationGlobal object containing the latitude/longitude dNorth
and dEast
metres from the
specified original_location
. The returned Location adds the entered alt
value to the altitude of the original_location
The function is useful when you want to move the vehicle around specifying locations relative to
the current vehicle position.
The algorithm is relatively accurate over small distances (10m within 1km) except close to the poles.
For more information see:
http://gis.stackexchange.com/questions/2951/algorithm-for-offsetting-a-latitude-longitude-by-some-amount-of-meters
earth_radius=6378137.0 #Radius of “spherical” earth
#Coordinate offsets in radians
dLat = dNorth/earth_radius
dLon = dEast/(earth_radiusmath.cos(math.pioriginal_location.lat/180))
#New position in decimal degrees
newlat = original_location.lat + (dLat * 180/math.pi)
newlon = original_location.lon + (dLon * 180/math.pi)
return LocationGlobal(newlat, newlon,original_location.alt+alt)
Listeners
home_position_set = False
#Create a message listener for home position fix
@vehicle.on_message(‘HOME_POSITION’)
def listener(self, name, home_position):
global home_position_set
home_position_set = True
Start mission example
wait for a home position lock
##while not home_position_set:
print “Waiting for home position…”
time.sleep(1)
Display basic vehicle state
print " Type: %s" % vehicle._vehicle_type
print " Armed: %s" % vehicle.armed
print " System status: %s" % vehicle.system_status.state
print " GPS: %s" % vehicle.gps_0
print " Alt: %s" % vehicle.location.global_relative_frame.alt
vehicle.armd = True
Change to AUTO mode
PX4setMode(MAV_MODE_AUTO)
time.sleep(1)
print " Mode: %s" % vehicle.mode
Load commands
cmds = vehicle.commands
cmds.clear()
home = vehicle.location.global_relative_frame
takeoff to 10 meters
wp = get_location_offset_meters(home, 0, 200, 300);
cmd = Command(0,0,0, mavutil.mavlink.MAV_FRAME_GLOBAL_RELATIVE_ALT, mavutil.mavlink.MAV_CMD_NAV_TAKEOFF, 0, 1, 0, 0, 0, 0, wp.lat, wp.lon, wp.alt)
cmd = Command(0, 0, 0, mavutil.mavlink.MAV_FRAME_GLOBAL_RELATIVE_ALT, mavutil.mavlink.MAV_CMD_NAV_TAKEOFF, 0, 0, 0, 0, 0, 0, wp.lat, wp.lon, wp.alt)
cmds.add(cmd)
move 10 meters north
wp = get_location_offset_meters(wp, 100, 0, 0);
cmd = Command(0,0,0, mavutil.mavlink.MAV_FRAME_GLOBAL_RELATIVE_ALT, mavutil.mavlink.MAV_CMD_NAV_WAYPOINT, 0, 1, 0, 0, 0, 0, wp.lat, wp.lon, wp.alt)
cmds.add(cmd)
move 10 meters east
wp = get_location_offset_meters(wp, 0, 100, 0);
cmds.add(cmd)
move 10 meters south
wp = get_location_offset_meters(wp, -100, 0, 0);
cmds.add(cmd)
move 10 meters west
wp = get_location_offset_meters(wp, 0, -100, 0);
cmds.add(cmd)
land
#wp = get_location_offset_meters(home, -891, 0, 0);
#cmd = Command(0,0,0, mavutil.mavlink.MAV_FRAME_GLOBAL_RELATIVE_ALT, #mavutil.mavlink.MAV_CMD_NAV_LAND, 0, 1, 0, 0, 0, 0, wp.lat, wp.lon, wp.alt)
cmds.add(cmd)
Upload mission
cmds.upload()
time.sleep(2)
Arm vehicle
vehicle.armed = True
monitor mission execution
nextwaypoint = vehicle.commands.next
while nextwaypoint < len(vehicle.commands):
if vehicle.commands.next > nextwaypoint:
display_seq = vehicle.commands.next+1
print “Moving to waypoint %s” % display_seq
time.sleep(1)
wait for the vehicle to land
while vehicle.commands.next > 0:
time.sleep(1)
Disarm vehicle
vehicle.armed = False
time.sleep(1)
#Close vehicle object before exiting script
vehicle.close()
time.sleep(1)
