I have written a custom mixer for an airframe and got it to work. It needs some fine tuning of the servos to get optimal geometry. Specifically I need to set the min/max and neutral positions for PWM outputs. I can do this on the RC inputs. There are parameters to do so, but all I see for the PWM outputs is min/max that applies to all 8 channels. Is there a way to set these individually or are you expected to scale the mixer outputs to include the extremes and neutral offset in the calculations? I can do that easily, but I just want to make sure that is the desired method.
Related topics
| Topic | Replies | Views | Activity | |
| Configure Min Max PWM on specific AUX port | 5 | 1665 | February 13, 2017 | |
| Pass through RC channels 6 and 7 on pixhawk mini | 3 | 2378 | June 30, 2017 | |
Setting PWM_OUT in new air frame configuration
0 | 569 | November 22, 2018 | |
Feature request - Set Aux Waypoint
4 | 1137 | January 20, 2018 | |
Minimum servo output
0 | 405 | August 31, 2017 |
