I strongly suspect there’s a bug in mission_raw_server_impl.cpp
probably here:
void MissionRawServerImpl::set_current_seq(std::size_t seq)
if (_current_mission.size() < static_cast<size_t>(seq)) {
return;
_current_seq = seq;
// If mission is over, just set item to last one again
auto item = seq == _current_mission.size() ? _current_mission.back() :
_current_mission.at(_current_seq);
auto converted_item = convert_item(item);
_parent->call_user_callback([this, converted_item]() {
if (_current_item_changed_callback) {
_current_item_changed_callback(converted_item);
mavlink_message_t mission_current;
mavlink_msg_mission_current_pack(
_parent->get_own_system_id(),
_parent->get_own_component_id(),
&mission_current,
static_cast<uint16_t>(_current_seq));
_parent->send_message(mission_current);
If the mission is empty the if statement on the top:
if (_current_seq + 1 > _current_mission.size()) {
return;
leave execution reach the line:
probably calling .back()
on empty mission cause a core dump.
BTW the problem is triggered by a, probably faulty, empty mission upload but it seems to be an acceptable behaviour for QGroundControl.
