MAVSDK-python MissionError: BUSY
My code is a simple mission upload to a SITL model in Gazebo.
It runs just fine and the mission is completed. I keep rerunning the code and it works perfectly, however, at some point, it starts to raise this error every time I run it.
The error disappears after I reboot ubuntu. But the same thing happens again after I run it for several times.
So, there must be something running in the background that causes this. I ended every python process running, but this didn’t solve it.
Here’s the error:
ahmed@ahmed:~/Documents/object_detection$ python3 sitl_mavsdk_mission.py
Waiting for mavsdk_server to be ready...
Connected to mavsdk_server!
home location
	>lat:38.161486599999996
	>lon:-122.45462169999999
  File "sitl_mavsdk_mission.py", line 168, in <module>
    mission_south=-10))
  File "/usr/lib/python3.6/asyncio/base_events.py", line 484, in run_until_complete
    return future.result()
  File "sitl_mavsdk_mission.py", line 107, in square_mission
    await drone.mission.clear_mission()     # Clear previous missions stored on drone
  File "/home/ahmed/.local/lib/python3.6/site-packages/mavsdk/generated/mission.py", line 717, in clear_mission
    raise MissionError(result, "clear_mission()")
mavsdk.generated.mission.MissionError: BUSY: 'Busy'; origin: clear_mission(); params: ()
Here is my code:
import asyncio
from mavsdk import System, MissionItem
import math
async def connect_sitl():
    drone = System()
    await drone.connect(system_address="udp://:14540")
    return drone
async def arm_drone(drone):
    await drone.action.arm()
async def print_flight_mode(drone):
    """ Prints the flight mode when it changes """
    previous_flight_mode = None
    async for flight_mode in drone.telemetry.flight_mode():
        if flight_mode is not previous_flight_mode:
            previous_flight_mode = flight_mode
            print(f"Flight mode: {flight_mode}")
async def takeoff(drone, takeoff_alt):
    # await drone.action.set_takeoff_altitude(altitude=takeoff_alt)     # Has issues
    await drone.param.set_float_param("MIS_TAKEOFF_ALT", takeoff_alt)
    await drone.action.takeoff()
    print('taking off..')
    prev_alt = None
    async for position in drone.telemetry.position():
        altitude = round(position.relative_altitude_m)
        if altitude != prev_alt:
            prev_alt = altitude
            print(f'altitude: {altitude}')
            if altitude == round(takeoff_alt):
                print('takeoff_alt reached successfully!')
                break
    return drone
async def land(drone=None):
    Drone is expected to be passed as an input if the function is called within a mission function (drone already connected)
    otherwise, drone is None and the function will connect to it.
    if drone is None:
        drone = await connect_sitl()
    await drone.action.land()
    print('landing..')
    return drone
async def takeoff_land(takeoff_alt):
    asyncio.ensure_future(print_flight_mode(drone)) # Start parallel task
    await arm_drone(drone)
    drone = await takeoff(drone=drone, takeoff_alt=takeoff_alt)
    # await asyncio.sleep(10)
    await land(drone)
async def print_mission_progress(drone):
    async for mission_progress in drone.mission.mission_progress():
        print(f"Mission progress: "
              f"{mission_progress.current_item_index}/"
              f"{mission_progress.mission_count}")
# used as a termination task in missions, so that the script keeps running as long as drone is in air
async def observe_is_in_air(drone):
    """ Monitors whether the drone is flying or not and
    returns after landing """
    was_in_air = False
    async for is_in_air in drone.telemetry.in_air():
        if is_in_air:
            was_in_air = is_in_air
        if was_in_air and not is_in_air:
            await asyncio.get_event_loop().shutdown_asyncgens()
            return
async def get_home_lat_lon(drone):
        home_lat = position.latitude_deg
        home_lon = position.longitude_deg
        break
    return home_lat, home_lon
def get_location_offset_meters(original_lat, original_lon, dNorth, dEast):
    earth_radius = 6378137.0    # Radius of "spherical" earth
    # Coordinate offsets in radians
    dLat = dNorth/earth_radius
    dLon = dEast/(earth_radius*math.cos(math.pi*original_lat/180))
    #New position in decimal degrees
    newlat = original_lat + (dLat * 180/math.pi)
    newlon = original_lon + (dLon * 180/math.pi)
    return newlat, newlon
async def square_mission(mission_alt=20, mission_spd=10, mission_north=10, mission_east=10, mission_south=-10):
    asyncio.ensure_future(print_mission_progress(drone)) # Parallel task
    termination_task = asyncio.ensure_future(observe_is_in_air(drone)) # keeps script running if drone in air
    home_lat, home_lon = await get_home_lat_lon(drone)
    print(f'home location\n\t>lat:{home_lat}\n\t>lon:{home_lon}')
    mission_items = []
    # Takeoff
    mission_items.append(MissionItem(home_lat,
                                     home_lon,
                                     mission_alt,
                                     mission_spd,
                                     is_fly_through=True,
                                     gimbal_pitch_deg=0,
                                     gimbal_yaw_deg=0,
                                     camera_action=MissionItem.CameraAction.NONE,
                                     loiter_time_s=float('nan'),
                                     camera_photo_interval_s=float('nan')))
    # Setting Mission waypoints
    wp_north = get_location_offset_meters(home_lat, home_lon, dNorth=mission_north, dEast=0)
    wp_east = get_location_offset_meters(wp_north[0], wp_north[1], dNorth=0, dEast=mission_east)
    wp_south = get_location_offset_meters(wp_east[0], wp_east[1], dNorth=mission_south, dEast=0)
    # Setting mission waypoints
    mission_items.append(MissionItem(wp_north[0],
                                     wp_north[1],
                                     mission_alt,
                                     mission_spd,
                                     gimbal_pitch_deg=0,
                                     gimbal_yaw_deg=0,
    mission_items.append(MissionItem(wp_east[0],
                                     wp_east[1],
                                     mission_alt,
                                     mission_spd,
                                     gimbal_pitch_deg=0,
                                     gimbal_yaw_deg=0,
    mission_items.append(MissionItem(wp_south[0],
                                     wp_south[1],
                                     mission_alt,
                                     mission_spd,
                                     gimbal_pitch_deg=0,
                                     gimbal_yaw_deg=0,
    await drone.mission.set_return_to_launch_after_mission(True)    # RTL after last wp
    await drone.mission.upload_mission(mission_items)
    await drone.mission.start_mission()
    await termination_task
if __name__ == "__main__":
    loop = asyncio.get_event_loop()
    # loop.run_until_complete(takeoff_land(20))
    loop.run_until_complete(square_mission(mission_alt=20, mission_spd=30,
                                                           mission_north=10,
                                                           mission_east=10,
                                                           mission_south=-10))
Thanks in advance.
I commented out this line and now it works fine.
I originally added it to clear the previously uploaded missions, but it doesn’t seem to be necessary.
Thanks for the note about this.
I will follow up on the issue here once we have fixed it: https://github.com/mavlink/MAVSDK-Python/issues/173
