Make px4_sitl gazebo fails with opencv aruco.hpp
I am following the standard instructions to run PX4 sitl with gazebo:
$ make px4_sitl gazebo
– Found PythonInterp: /usr/bin/python3 (found suitable version “3.8.10”, minimum required is “3”)
– Found OpenCV: /usr/local (found version “4.5.0”)
– Found TinyXML: /usr/lib/x86_64-linux-gnu/libtinyxml.so
…/Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/include/gazebo_aruco_plugin.h:41:10: fatal error: opencv2/aruco.hpp: No such file or directory
41 | #include <opencv2/aruco.hpp>
compilation terminated.
$ make px4_sitl jmavsim
Works fine and the JMAVsim runs correctly with QGroundControl.
I am correctly initialized, have tracked down numerous unmarked dependencies, re-installed, rebuilt, cleaned. to no avail.
Sadly I am left with building opencv + contrib (aruco is in the contrib portion)…
Any other help would be appreciated…
Are you checked out to a release version or just on main branch? I solved this problem by checking out to the latest release then running the environment setup script again
I built OpenCV 4.3 and that solved the problem. Ironically I set the OpenCV version just as you suggested - though it was documented.
I’ll remember your fix though - less work than rebuilding OpenCV…
Thanks for the help!
