Make px4_sitl fails with no aruco/dictionary.hpp
My setup is
  • Ubuntu 20.04LTS + RTX3060Ti (CUDA 12.2 installed)
  • Opencv 4.8.0 build installed with contrib library
For px4 v1.14.0 make px4_sitl gazebo fails as following.
$ make px4_sitl gazebo
-- PX4 version: v1.14.0-rc2-8-g40c9789e7d (1.14.0)
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
-- PX4 config file: /home/kyu/px4/px4-Firmware/boards/px4/sitl/default.px4board
-- PLATFORM posix
-- ROMFSROOT px4fmu_common
-- ROOTFSDIR .
-- TESTING y
-- ETHERNET y
-- PX4 config: px4_sitl_default
-- PX4 platform: posix
-- PX4 lockstep: enabled
-- The CXX compiler identification is GNU 9.4.0
-- The C compiler identification is GNU 9.4.0
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/cc
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- cmake build type: RelWithDebInfo
-- Could NOT find gz-transport (missing: gz-transport_DIR)
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for module 'bullet>=2.82'
--   Found bullet, version 2.88
-- Found ccd: /usr/include (found suitable version "2.0", minimum required is "2.0")
-- Found fcl: /usr/include (found suitable version "0.5.0", minimum required is "0.3.2")
-- Found assimp: /usr/include (found version "5.0.0")
-- Found DART: /usr/include (Required is at least version "6.6") found components: dart
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found suitable version "1.71.0", minimum required is "1.40.0") found components: thread system filesystem program_options regex iostreams date_time
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread (found version "3.6.1")
-- Looking for ignition-math6 -- found version 6.15.0
-- Searching for dependencies of ignition-math6
-- Looking for OGRE...
-- OGRE_PREFIX_WATCH changed.
-- Checking for module 'OGRE'
--   Found OGRE, version 1.9.0
-- Found OGRE: optimized;/usr/lib/x86_64-linux-gnu/libOgreMain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreMain.so
-- Looking for OGRE_Paging...
-- Found OGRE_Paging: optimized;/usr/lib/x86_64-linux-gnu/libOgrePaging.so;debug;/usr/lib/x86_64-linux-gnu/libOgrePaging.so
-- Found OGRE_Terrain: optimized;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so
-- Found OGRE_Property: optimized;/usr/lib/x86_64-linux-gnu/libOgreProperty.so;debug;/usr/lib/x86_64-linux-gnu/libOgreProperty.so
-- Found OGRE_RTShaderSystem: optimized;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so;debug;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so
-- Looking for OGRE_Volume...
-- Found OGRE_Volume: optimized;/usr/lib/x86_64-linux-gnu/libOgreVolume.so;debug;/usr/lib/x86_64-linux-gnu/libOgreVolume.so
-- Found OGRE_Overlay: optimized;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so;debug;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so
-- Looking for ignition-transport8 -- found version 8.4.0
-- Searching for dependencies of ignition-transport8
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread (found suitable version "3.6.1", minimum required is "3")
-- Config-file not installed for ZeroMQ -- checking for pkg-config
-- Checking for module 'libzmq >= 4'
--   Found libzmq , version 4.3.2
-- Found ZeroMQ: TRUE (Required is at least version "4")
-- Checking for module 'uuid'
--   Found uuid, version 2.34.0
-- Found UUID: TRUE
-- Looking for ignition-msgs5 -- found version 5.11.0
-- Searching for dependencies of ignition-msgs5
-- Checking for module 'tinyxml2'
--   Found tinyxml2, version 6.2.0
-- Looking for ignition-common3 -- found version 3.16.0
-- Searching for dependencies of ignition-common3
-- Looking for dlfcn.h - found
-- Looking for libdl - found
-- Found DL: TRUE
-- Searching for <ignition-common3> component [graphics]
-- Looking for ignition-common3-graphics -- found version 3.16.0
-- Searching for dependencies of ignition-common3-graphics
-- Looking for ignition-fuel_tools4 -- found version 4.9.0
-- Searching for dependencies of ignition-fuel_tools4
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.68.0")
-- Checking for module 'jsoncpp'
--   Found jsoncpp, version 1.7.4
-- Found JSONCPP: TRUE
-- Checking for module 'yaml-0.1'
--   Found yaml-0.1, version 0.2.2
-- Found YAML: TRUE
-- Checking for module 'libzip'
--   Found libzip, version 1.5.1
-- Found ZIP: TRUE
-- Found gazebo-classic 11.14.0, including sitl_gazebo-classic simulator and gazebo-classic targets
-- Found Java: /usr/bin/java (found version "13.0.7")
-- ROMFS: ROMFS/px4fmu_common
Architecture:  amd64
==> CPACK_INSTALL_PREFIX = @DEB_INSTALL_PREFIX@
-- Configuring done
-- Generating done
-- Build files have been written to: /home/kyu/px4/px4-Firmware/build/px4_sitl_default
[0/903] git submodule src/drivers/gps/devices
[2/903] git submodule src/modules/mavlink/mavlink
[6/903] git submodule Tools/simulation/gazebo-classic/sitl_gazebo-classic
[11/903] git submodule src/modules/uxrce_dds_client/Micro-XRCE-DDS-Client
[17/903] Performing configure step for 'sitl_gazebo-classic'
-- install-prefix: /usr/local
-- Performing Test COMPILER_SUPPORTS_CXX17
-- Performing Test COMPILER_SUPPORTS_CXX17 - Success
-- Performing Test COMPILER_SUPPORTS_CXX14
-- Performing Test COMPILER_SUPPORTS_CXX14 - Success
-- Performing Test COMPILER_SUPPORTS_CXX11
-- Performing Test COMPILER_SUPPORTS_CXX11 - Success
-- Performing Test COMPILER_SUPPORTS_CXX0X
-- Performing Test COMPILER_SUPPORTS_CXX0X - Success
-- Using C++17 standard
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found suitable version "1.71.0", minimum required is "1.58") found components: system thread filesystem
-- Found UUID: TRUE
-- Found DL: TRUE
-- Found YAML: TRUE
-- Found ZIP: TRUE
-- Checking for one of the modules 'glib-2.0'
-- Found Threads: TRUE
-- Found CUDA: /usr/local/cuda-12.2 (found suitable exact version "12.2")
-- Found OpenCV: /usr/local (found version "4.8.0")
-- Found TinyXML: /usr/lib/x86_64-linux-gnu/libtinyxml.so
-- Checking for module 'gstreamer-1.0 >= 1.0'
--   Found gstreamer-1.0 , version 1.16.3
-- Checking for module 'gstreamer-base-1.0 >= 1.0'
--   Found gstreamer-base-1.0 , version 1.16.3
-- Checking for module 'gstreamer-app-1.0 >= 1.0'
--   Found gstreamer-app-1.0 , version 1.16.3
-- Found GStreamer: GSTREAMER_INCLUDE_DIRS;GSTREAMER_LIBRARIES;GSTREAMER_VERSION;GSTREAMER_BASE_INCLUDE_DIRS;GSTREAMER_BASE_LIBRARIES (Required is at least version "1.0")
CMake Deprecation Warning at external/OpticalFlow/CMakeLists.txt:34 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
CMake Deprecation Warning at external/OpticalFlow/external/klt_feature_tracker/CMakeLists.txt:1 (cmake_minimum_required):
  CMake.
-- Found MAVLink: /home/kyu/px4/px4-Firmware/build/px4_sitl_default/mavlink (found version "2.0")
-- catkin DISABLED
-- Checking for module 'protobuf'
--   Found protobuf, version 3.6.1
-- Gazebo version: 11.14
-- Found GStreamer: adding gst_camera_plugin
-- Found GStreamer: adding gst_video_stream_widget
-- Configuring done
-- Generating done
-- Build files have been written to: /home/kyu/px4/px4-Firmware/build/px4_sitl_default/build_gazebo-classic
[610/903] Performing build step for 'sitl_gazebo-classic'
[1/142] Generating /home/kyu/px4/px4-k...dels/advanced_plane/advanced_plane.sdf
/home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models/advanced_plane/advanced_plane.sdf.jinja -> /home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models/advanced_plane/advanced_plane.sdf
[68/142] Building CXX object CMakeFile...ugin.dir/src/gazebo_aruco_plugin.cpp.o
FAILED: CMakeFiles/gazebo_aruco_plugin.dir/src/gazebo_aruco_plugin.cpp.o
/usr/bin/c++ -DBOOST_ALL_NO_LIB -DBOOST_ATOMIC_DYN_LINK -DBOOST_DATE_TIME_DYN_LINK -DBOOST_FILESYSTEM_DYN_LINK -DBOOST_IOSTREAMS_DYN_LINK -DBOOST_PROGRAM_OPTIONS_DYN_LINK -DBOOST_REGEX_DYN_LINK -DBOOST_SYSTEM_DYN_LINK -DBOOST_TEST_DYN_LINK -DBOOST_THREAD_DYN_LINK -DLIBBULLET_VERSION=2.88 -DLIBBULLET_VERSION_GT_282 -Dgazebo_aruco_plugin_EXPORTS -I/home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/include -I/home/kyu/px4/px4-Firmware/build/px4_sitl_default/build_gazebo-classic -I/usr/include/eigen3/eigen3 -I/usr/include/gazebo-11/gazebo/msgs -I/home/kyu/px4/px4-Firmware/build/px4_sitl_default/mavlink -I/home/kyu/px4/px4-Firmware/build/px4_sitl_default/mavlink/mavlink/v2.0 -I/home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/external/OpticalFlow/include -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -isystem /usr/include/gazebo-11 -isystem /usr/include/bullet -isystem /usr/include/simbody -isystem /usr/include/sdformat-9.10 -isystem /usr/include/ignition/math6 -isystem /usr/include/OGRE -isystem /usr/include/OGRE/Terrain -isystem /usr/include/OGRE/Paging -isystem /usr/include/ignition/transport8 -isystem /usr/include/ignition/msgs5 -isystem /usr/include/ignition/common3 -isystem /usr/include/ignition/fuel_tools4 -isystem /usr/include/x86_64-linux-gnu/qt5 -isystem /usr/include/x86_64-linux-gnu/qt5/QtCore -isystem /usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -isystem /usr/include/eigen3 -isystem /usr/local/include/opencv4 -isystem /usr/include/sdformat-9.10/sdf/.. -isystem /usr/include/ignition/cmake2 -isystem /usr/include/uuid -O2 -g -DNDEBUG -fPIC -Wno-deprecated-declarations -Wno-address-of-packed-member -I/usr/include/uuid -std=gnu++17 -MD -MT CMakeFiles/gazebo_aruco_plugin.dir/src/gazebo_aruco_plugin.cpp.o -MF CMakeFiles/gazebo_aruco_plugin.dir/src/gazebo_aruco_plugin.cpp.o.d -o CMakeFiles/gazebo_aruco_plugin.dir/src/gazebo_aruco_plugin.cpp.o -c /home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/src/gazebo_aruco_plugin.cpp
In file included from /home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/src/gazebo_aruco_plugin.cpp:31:
/home/kyu/px4/px4-Firmware/Tools/simulation/gazebo-classic/sitl_gazebo-classic/include/gazebo_aruco_plugin.h:42:10: fatal error: opencv2/aruco/dictionary.hpp: No such file or directory
   42 | #include <opencv2/aruco/dictionary.hpp>
compilation terminated.
[84/142] Building CXX object CMakeFile...ir/src/gazebo_opticalflow_plugin.cpp.o
[899/903] Linking CXX executable bin/px4
FAILED: external/Stamp/sitl_gazebo-classic/sitl_gazebo-classic-build /home/kyu/px4/px4-Firmware/build/px4_sitl_default/external/Stamp/sitl_gazebo-classic/sitl_gazebo-classic-build
cd /home/kyu/px4/px4-Firmware/build/px4_sitl_default/build_gazebo-classic && /usr/bin/cmake --build /home/kyu/px4/px4-Firmware/build/px4_sitl_default/build_gazebo-classic -- -j 17
make: *** [Makefile:232: px4_sitl] Error 1
I checked /usr/include folder and there is the file but px4 cannot find it?
$ cd /usr/include/opencv4/opencv2/aruco/
/usr/include/opencv4/opencv2/aruco$ ls
charuco.hpp  dictionary.hpp
Thanks to @ryanjAA
This issue is resolved by applying below fix.
Hello, i have the same question with you!
In file included from /home/jetson/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/src/gazebo_aruco_plugin.cpp:31:
/home/jetson/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/include/gazebo_aruco_plugin.h:42:10: fatal error: opencv2/aruco.hpp: No such file or directory
42 | #include <opencv2/aruco.hpp>
cd /home/jetson/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic && /usr/bin/cmake --build /home/jetson/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic – -j 1
and I’m looking for advice on how to solve this problem. THANKS!
