I’m trying to use PX4 gazebo simulation v1.8.0 on linux 18.04. But I’m facing some issues.
Whenever I’m trying to build file using
make posix_sitl_default gazebo
I get this.
> -- PX4 VERSION: v1.8.0
> -- CONFIG: posix_sitl_default
> -- Build Type: RelWithDebInfo
> -- The CXX compiler identification is GNU 5.5.0
> -- The C compiler identification is GNU 5.5.0
> -- The ASM compiler identification is GNU
> -- Found assembler: /usr/bin/cc
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Detecting CXX compile features
> -- Detecting CXX compile features - done
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Found PythonInterp: /usr/bin/python (found version "2.7.17")
> -- Found PY_jinja2: /home/gps/.local/lib/python2.7/site-packages/jinja2
> -- C compiler: cc (Ubuntu 5.5.0-12ubuntu1) 5.5.0 20171010
> -- C++ compiler: c++ (Ubuntu 5.5.0-12ubuntu1) 5.5.0 20171010
> Submodule 'msg/tools/gencpp' (https://github.com/ros/gencpp.git) registered for path 'tools/gencpp'
> Submodule path 'tools/gencpp': checked out 'b41ee3060badd660662e21cd9d4f81971c87a420'
> Submodule 'msg/tools/genmsg' (https://github.com/ros/genmsg.git) registered for path 'tools/genmsg'
> Submodule path 'tools/genmsg': checked out 'a189fc78558e7276df59d2961cfe4f8b4de08a8b'
> Submodule 'src/lib/DriverFramework' (https://github.com/PX4/DriverFramework.git) registered for path 'src/lib/DriverFramework'
> Submodule path 'src/lib/DriverFramework': checked out '410e9fc4e78da91030e9d535a7f8e023a9ddd1f4'
> Submodule path 'src/lib/DriverFramework/dspal': checked out '9b46b4a57f230672ee0806a523963af70bc44f1c'
> Submodule path 'src/lib/DriverFramework/dspal/cmake_hexagon': checked out '07168bd5715818802b78f674816ec851307998a7'
> Submodule 'src/lib/ecl' (https://github.com/PX4/ecl.git) registered for path 'ecl'
> Submodule path 'ecl': checked out '1a1106878d6ab1cc48565bef9b25b07d626c5d0b'
> Submodule 'src/lib/matrix' (https://github.com/PX4/Matrix.git) registered for path 'matrix'
> Submodule path 'matrix': checked out 'b815fc97c4e686a93a8074f27d1830a031b0d38d'
> -- PX4 ECL: Very lightweight Estimation & Control Library v0.9.0-553-g1a11068
> Submodule 'src/drivers/gps/devices' (https://github.com/PX4/GpsDrivers.git) registered for path 'devices'
> Submodule path 'devices': checked out 'a5cf54a2e14e1c6f3ff443f7f13eba31782c0460'
> Submodule 'mavlink/include/mavlink/v2.0' (https://github.com/mavlink/c_library_v2.git) registered for path '../../../mavlink/include/mavlink/v2.0'
> Submodule path '../../../mavlink/include/mavlink/v2.0': checked out '033fa8e7a4a75a0c3f17cea57e3be8966e05f770'
> Submodule 'Tools/sitl_gazebo' (https://github.com/PX4/sitl_gazebo.git) registered for path '../../Tools/sitl_gazebo'
> Submodule path '../../Tools/sitl_gazebo': checked out 'b5a92095bfb1b6a218a80f58ad9fe09c89ef4598'
> Submodule path '../../Tools/sitl_gazebo/external/OpticalFlow': checked out '549cc7cacb01bb71b2386586305c889d3651cfcc'
> Submodule path '../../Tools/sitl_gazebo/external/OpticalFlow/external/klt_feature_tracker': checked out 'a0d242294ef638d8fa422ab43f0d476ba37a15a6'
> Submodule 'Tools/jMAVSim' (https://github.com/PX4/jMAVSim.git) registered for path '../../Tools/jMAVSim'
> Submodule path '../../Tools/jMAVSim': checked out 'e0e8b6ca473a6eecc3ee2984ea414e321f6808c6'
> Submodule path '../../Tools/jMAVSim/jMAVlib': checked out 'afa488d166813038c28572907eacf6eaa54f3c7c'
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/gps/src/Firmware/build/posix_sitl_default
> ninja: Entering directory `/home/gps/src/Firmware/build/posix_sitl_default'
> [632/636] Performing configure step for 'sitl_gazebo'
> -- install-prefix: /usr/local
> -- Looking for pthread.h
> -- Looking for pthread.h - found
> -- Looking for pthread_create
> -- Looking for pthread_create - not found
> -- Looking for pthread_create in pthreads
> -- Looking for pthread_create in pthreads - not found
> -- Looking for pthread_create in pthread - found
> -- Found Threads: TRUE
> -- Boost version: 1.65.1
> -- Found the following Boost libraries:
> -- system
> -- thread
> -- timer
> -- chrono
> -- date_time
> -- atomic
> -- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
> -- Checking for module 'bullet>=2.82'
> -- Found bullet, version 2.87
> -- Found Simbody: /usr/include/simbody
> -- thread
> -- system
> -- filesystem
> -- program_options
> -- regex
> -- iostreams
> -- date_time
> -- chrono
> -- atomic
> -- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread (found version "3.0.0")
> -- Looking for OGRE...
> -- OGRE_PREFIX_WATCH changed.
> -- Checking for module 'OGRE'
> -- Found OGRE, version 1.9.0
> -- Found Ogre Ghadamon (1.9.0)
> -- Found OGRE: optimized;/usr/lib/x86_64-linux-gnu/libOgreMain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreMain.so
> -- Looking for OGRE_Paging...
> -- Found OGRE_Paging: optimized;/usr/lib/x86_64-linux-gnu/libOgrePaging.so;debug;/usr/lib/x86_64-linux-gnu/libOgrePaging.so
> -- Looking for OGRE_Terrain...
> -- Found OGRE_Terrain: optimized;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so
> -- Looking for OGRE_Property...
> -- Found OGRE_Property: optimized;/usr/lib/x86_64-linux-gnu/libOgreProperty.so;debug;/usr/lib/x86_64-linux-gnu/libOgreProperty.so
> -- Looking for OGRE_RTShaderSystem...
> -- Found OGRE_RTShaderSystem: optimized;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so;debug;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so
> -- Looking for OGRE_Volume...
> -- Found OGRE_Volume: optimized;/usr/lib/x86_64-linux-gnu/libOgreVolume.so;debug;/usr/lib/x86_64-linux-gnu/libOgreVolume.so
> -- Looking for OGRE_Overlay...
> -- Found OGRE_Overlay: optimized;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so;debug;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so
> -- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread;-lpthread (found suitable version "3.0.0", minimum required is "2.3.0")
> -- Config-file not installed for ZeroMQ -- checking for pkg-config
> -- Checking for module 'libzmq >= 4'
> -- Found libzmq , version 4.2.5
> -- Found ZeroMQ: TRUE (Required is at least version "4")
> -- Checking for module 'uuid'
> -- Found uuid, version 2.31.1
> -- Found UUID: TRUE
> -- Checking for module 'tinyxml2'
> -- Found tinyxml2, version 6.0.0
> -- Looking for dlfcn.h - found
> -- Looking for libdl - found
> -- Found DL: TRUE
> -- FreeImage.pc not found, we will search for FreeImage_INCLUDE_DIRS and FreeImage_LIBRARIES
> -- Checking for module 'gts'
> -- Found gts, version 0.7.6
> -- Found GTS: TRUE
> -- Checking for module 'libswscale'
> -- Found libswscale, version 4.8.100
> -- Found SWSCALE: TRUE
> -- Checking for module 'libavdevice >= 56.4.100'
> -- Found libavdevice , version 57.10.100
> -- Found AVDEVICE: TRUE (Required is at least version "56.4.100")
> -- Checking for module 'libavformat'
> -- Found libavformat, version 57.83.100
> -- Found AVFORMAT: TRUE
> -- Checking for module 'libavcodec'
> -- Found libavcodec, version 57.107.100
> -- Found AVCODEC: TRUE
> -- Checking for module 'libavutil'
> -- Found libavutil, version 55.78.100
> -- Found AVUTIL: TRUE
> -- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.58.0")
> -- Checking for module 'jsoncpp'
> -- Found jsoncpp, version 1.7.4
> -- Found JSONCPP: TRUE
> -- Checking for module 'yaml-0.1'
> -- Found yaml-0.1, version 0.1.7
> -- Found YAML: TRUE
> -- Checking for module 'libzip'
> -- Found libzip, version 1.1.2
> -- Found ZIP: TRUE
> -- Found OpenCV: /usr/local (found version "4.2.0")
> -- Found TinyXML: /usr/lib/x86_64-linux-gnu/libtinyxml.so
> -- Building klt_feature_tracker without catkin
> -- Building OpticalFlow with OpenCV
> -- Found MAVLink: /home/gps/src/Firmware/mavlink/include (found version "2.0")
> -- catkin DISABLED
> -- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so;-lpthread;-lpthread;-lpthread (found version "3.0.0")
> -- Checking for module 'protobuf'
> -- Found protobuf, version 3.0.0
> Gazebo version: 9.19
> -- Performing Test COMPILER_SUPPORTS_CXX17
> -- Performing Test COMPILER_SUPPORTS_CXX17 - Success
> -- Performing Test COMPILER_SUPPORTS_CXX14
> -- Performing Test COMPILER_SUPPORTS_CXX14 - Success
> -- Performing Test COMPILER_SUPPORTS_CXX11
> -- Performing Test COMPILER_SUPPORTS_CXX11 - Success
> -- Performing Test COMPILER_SUPPORTS_CXX0X
> -- Performing Test COMPILER_SUPPORTS_CXX0X - Success
> -- Using C++17 compiler
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/gps/src/Firmware/build/posix_sitl_default/build_gazebo
> [633/636] Performing build step for 'sitl_gazebo'
> FAILED: external/Stamp/sitl_gazebo/sitl_gazebo-build
> cd /home/gps/src/Firmware/build/posix_sitl_default/build_gazebo && /usr/bin/cmake --build . && /usr/bin/cmake -E touch /home/gps/src/Firmware/build/posix_sitl_default/external/Stamp/sitl_gazebo/sitl_gazebo-build
> [1/73] Running C++ protocol buffer compiler on msgs/MotorSpeed.proto
> [2/73] Running C++ protocol buffer compiler on msgs/Range.proto
> [3/73] Running C++ protocol buffer compiler on msgs/Groundtruth.proto
> [4/73] Running C++ protocol buffer compiler on msgs/SITLGps.proto
> [5/73] Running C++ protocol buffer compiler on msgs/OpticalFlow.proto
> [6/73] Running C++ protocol buffer compiler on msgs/CommandMotorSpeed.proto
> [7/73] Running C++ protocol buffer compiler on msgs/Odometry.proto
> [8/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/c920/c920-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/c920/c920.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/c920/c920-gen.sdf
> [9/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/pixhawk/pixhawk-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/pixhawk/pixhawk.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/pixhawk/pixhawk-gen.sdf
> [10/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag-gen.sdf
> [11/73] Running C++ protocol buffer compiler on msgs/Int32.proto
> [12/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4-gen.sdf
> [13/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/px4flow/px4flow-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/px4flow/px4flow.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/px4flow/px4flow-gen.sdf
> [14/73] Running C++ protocol buffer compiler on msgs/Imu.proto
> [15/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/matrice_100/matrice_100-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/matrice_100/matrice_100.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/matrice_100/matrice_100-gen.sdf
> [16/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/sf10a/sf10a-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/sf10a/sf10a.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/sf10a/sf10a-gen.sdf
> [17/73] Running C++ protocol buffer compiler on msgs/IRLock.proto
> [18/73] Running C++ protocol buffer compiler on msgs/Float.proto
> [19/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/r200/r200-gen.sdf
> /home/gps/src/Firmware/Tools/sitl_gazebo/models/r200/r200.sdf.jinja -> /home/gps/src/Firmware/Tools/sitl_gazebo/models/r200/r200-gen.sdf
> [20/73] Building CXX object CMakeFiles/gazebo_mavlink_interface.dir/src/geo_mag_declination.cpp.o
> [21/73] Building CXX object OpticalFlow/CMakeFiles/OpticalFlow.dir/src/optical_flow.cpp.o
> [22/73] Building CXX object OpticalFlow/CMakeFiles/OpticalFlow.dir/src/flow_px4.cpp.o
> [23/73] Building CXX object OpticalFlow/CMakeFiles/OpticalFlow.dir/src/px4flow.cpp.o
> [24/73] Building CXX object CMakeFiles/mav_msgs.dir/MotorSpeed.pb.cc.o
> [25/73] Building CXX object CMakeFiles/std_msgs.dir/Int32.pb.cc.o
> [26/73] Building CXX object CMakeFiles/mav_msgs.dir/CommandMotorSpeed.pb.cc.o
> [27/73] Building CXX object CMakeFiles/sensor_msgs.dir/Float.pb.cc.o
> [28/73] Building CXX object CMakeFiles/nav_msgs.dir/Odometry.pb.cc.o
> [29/73] Linking CXX shared library libmav_msgs.so
> [30/73] Generating /home/gps/src/Firmware/Tools/sitl_gazebo/models/iris/iris.sdf
> [31/73] Linking CXX shared library libnav_msgs.so
> [32/73] Building CXX object CMakeFiles/sensor_msgs.dir/IRLock.pb.cc.o
> [33/73] Building CXX object CMakeFiles/sensor_msgs.dir/Groundtruth.pb.cc.o
> [34/73] Building CXX object CMakeFiles/gazebo_geotagged_images_plugin.dir/src/gazebo_geotagged_images_plugin.cpp.o
> FAILED: CMakeFiles/gazebo_geotagged_images_plugin.dir/src/gazebo_geotagged_images_plugin.cpp.o
> /usr/bin/c++ -DLIBBULLET_VERSION=2.87 -DLIBBULLET_VERSION_GT_282 -Dgazebo_geotagged_images_plugin_EXPORTS -isystem /usr/include/gazebo-9 -isystem /usr/include/bullet -isystem /usr/include/simbody -isystem /usr/include/sdformat-6.3 -isystem /usr/include/ignition/math4 -isystem /usr/include/OGRE -isystem /usr/include/OGRE/Terrain -isystem /usr/include/OGRE/Paging -isystem /usr/include/ignition/transport4 -isystem /usr/include/ignition/msgs1 -isystem /usr/include/ignition/common1 -isystem /usr/include/ignition/fuel_tools1 -I/home/gps/src/Firmware/Tools/sitl_gazebo/include -I. -I/usr/include/eigen3 -I/usr/include/eigen3/eigen3 -I/usr/include/gazebo-9/gazebo/msgs -I/home/gps/src/Firmware/mavlink/include -isystem /usr/local/include/opencv4 -I/home/gps/src/Firmware/Tools/sitl_gazebo/external/OpticalFlow/include -isystem /usr/include/uuid -isystem /usr/include/x86_64-linux-gnu -std=c++17 -std=c++11 -Wno-deprecated-declarations -fPIC -I/usr/include/uuid -I/usr/include/x86_64-linux-gnu -std=gnu++14 -MD -MT CMakeFiles/gazebo_geotagged_images_plugin.dir/src/gazebo_geotagged_images_plugin.cpp.o -MF CMakeFiles/gazebo_geotagged_images_plugin.dir/src/gazebo_geotagged_images_plugin.cpp.o.d -o CMakeFiles/gazebo_geotagged_images_plugin.dir/src/gazebo_geotagged_images_plugin.cpp.o -c /home/gps/src/Firmware/Tools/sitl_gazebo/src/gazebo_geotagged_images_plugin.cpp
> /home/gps/src/Firmware/Tools/sitl_gazebo/src/gazebo_geotagged_images_plugin.cpp:25:16: fatal error: cv.h: No such file or directory
> compilation terminated.
> [35/73] Linking CXX shared library libstd_msgs.so
> [36/73] Building CXX object CMakeFiles/LiftDragPlugin.dir/src/liftdrag_plugin/liftdrag_plugin.cpp.o
> [37/73] Building CXX object CMakeFiles/gazebo_imu_plugin.dir/src/gazebo_imu_plugin.cpp.o
> [38/73] Building CXX object CMakeFiles/gazebo_gimbal_controller_plugin.dir/src/gazebo_gimbal_controller_plugin.cpp.o
> [39/73] Building CXX object CMakeFiles/gazebo_vision_plugin.dir/src/gazebo_vision_plugin.cpp.o
> [40/73] Building CXX object CMakeFiles/gazebo_motor_model.dir/src/gazebo_motor_model.cpp.o
> [41/73] Building CXX object CMakeFiles/gazebo_multirotor_base_plugin.dir/src/gazebo_multirotor_base_plugin.cpp.o
> [42/73] Building CXX object CMakeFiles/gazebo_controller_interface.dir/src/gazebo_controller_interface.cpp.o
> [43/73] Building CXX object CMakeFiles/gazebo_mavlink_interface.dir/src/gazebo_mavlink_interface.cpp.o
> ninja: build stopped: subcommand failed.
> Makefile:148: recipe for target 'posix_sitl_default' failed
> make: *** [posix_sitl_default] Error 1
It seem gazebo sitl is having an issue. How should I fix this?
