Magnetometer failsafe: YES (1 events)
I’m testing a few Black Cube Autopilots and sometimes I see “sensors status” return a failsafe event on the magnetometers.
Can anyone explain what might be triggering this? Is an internal mag sending bad data or did it timeout?
error count is 0 for all 3 mags.
This happens consistently every boot.
INFO  [ecl/validation] validator: best: 0, prev best: 2, failsafe: YES (1 events)
INFO  [ecl/validation] sensor #0, prio: 75, state: OK
INFO  [ecl/validation] 	val:  -0.4198, lp:  -0.4237 mean dev:   0.0000 RMS:   0.0078 conf:   1.0000
INFO  [ecl/validation] 	val:   0.1628, lp:   0.1620 mean dev:   0.0000 RMS:   0.0078 conf:   1.0000
INFO  [ecl/validation] 	val:   0.7605, lp:   0.7501 mean dev:   0.0000 RMS:   0.0166 conf:   1.0000
INFO  [ecl/validation] sensor #1, prio: 50, state: OK
INFO  [ecl/validation] 	val:   0.0226, lp:   0.0240 mean dev:  -0.0000 RMS:   0.0034 conf:   1.0000
INFO  [ecl/validation] 	val:  -0.2786, lp:  -0.2904 mean dev:  -0.0001 RMS:   0.0122 conf:   1.0000
INFO  [ecl/validation] 	val:   0.4233, lp:   0.4158 mean dev:  -0.0000 RMS:   0.0086 conf:   1.0000
INFO  [ecl/validation] sensor #2, prio: 75, state: OK
INFO  [ecl/validation] 	val:   0.4310, lp:   0.4318 mean dev:  -0.0002 RMS:   0.0357 conf:   1.0000
INFO  [ecl/validation] 	val:  -0.7049, lp:  -0.7078 mean dev:   0.0001 RMS:   0.0122 conf:   1.0000
INFO  [ecl/validation] 	val:   0.0135, lp:   0.0298 mean dev:   0.0001 RMS:   0.0266 conf:   1.0000
@rroche? How can we help on this topic?
No error count, yet a failsafe is strange.
Digging through the code it looks like it may just be a reprioritization of the 3 internal mags based on confidence level - not that any of them has had a failure. I think “failsafe” may not be the best term but the same reordering of priority also occurs when a mag fails.
This doesn’t occur when an external mag is used.
Very good! Good to hear there is nothing actually wrong here, some improvements to messages may make this less confusing, maybe you may be able to think of a better wording and do a Pull request?
Thanks for the reply @proficnc :tada:
@dlwalter I agree with @proficnc if you have an a few extra minutes to spare a PR would be much appreciated.
