MacOS Development Environment Setup
Do I still need to perform the following steps in the newer MacOS? I am on Sequoia 15.7.2 with M4 Pro.
Also I executed these steps in virtual environment.
brew install --cask temurin
brew install --cask xquartz
brew install px4-sim-gazebo
Thank you,
Mustafa
  1. Run the following commands in your shell:
    brew unlink tbb
    sed -i.bak '/disable! date:/s/^/  /; /disable! date:/s/./#/3' $(brew --prefix)/Library/Taps/homebrew/homebrew-core/Formula/tbb@2020.rb
    brew install tbb@2020
    brew link tbb@2020
Hello again,
I proceeded to build steps for gazebo-classic_iris because I read it somewhere. It failed with the following error at the bottom of this log. I tired wit gazebo-classic that did not work either. I cleaned distribution but no change. Should I delete the repo and restart my MacBook and try again?
Mustafa
(venv) mustafacayci@Mustafas-MacBook-Pro PX4-Autopilot % make px4_sitl gazebo-classic_iris
-- PX4_GIT_TAG: v1.17.0-alpha1-292-gaa850d5c1c
CMake Warning (dev) at CMakeLists.txt:176 (find_package):
  Policy CMP0148 is not set: The FindPythonInterp and FindPythonLibs modules
  are removed.  Run "cmake --help-policy CMP0148" for policy details.  Use
  the cmake_policy command to set the policy and suppress this warning.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Found PythonInterp: /Users/mustafacayci/Documents/Projects/px4/venv/bin/python3 (found suitable version "3.14.2", minimum required is "3")
-- PX4 config file: /Users/mustafacayci/Documents/Projects/px4/PX4-Autopilot/boards/px4/sitl/default.px4board
-- PLATFORM posix
-- ROMFSROOT px4fmu_common
-- TESTING y
-- ETHERNET y
-- ROOT_PATH .
-- PARAM_FILE /fs/mtd_params
-- PX4 config: px4_sitl_default
-- PX4 platform: posix
-- PX4 lockstep: enabled
-- The CXX compiler identification is AppleClang 17.0.0.17000404
-- The C compiler identification is AppleClang 17.0.0.17000404
-- The ASM compiler identification is AppleClang
-- Found assembler: /usr/bin/cc
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- cmake build type: RelWithDebInfo
-- ccache enabled (export CCACHE_DISABLE=1 to disable)
CMake Deprecation Warning at platforms/posix/src/px4/common/lockstep_scheduler/CMakeLists.txt:1 (cmake_minimum_required):
  Compatibility with CMake < 3.10 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value.  Or, use the <min>...<max> syntax
  to tell CMake that the project requires at least <min> but has been updated
  to work with policies introduced by <max> or earlier.
-- Looking for gz-transport13 -- found version 13.5.0
-- Searching for dependencies of gz-transport13
-- Found ZLIB: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/lib/libz.tbd (found version "1.2.12")
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Config-file not installed for ZeroMQ -- checking for pkg-config
-- Checking for module 'libzmq >= 4'
--   Found libzmq, version 4.3.5
-- Found ZeroMQ: TRUE (Required is at least version "4")
-- Found UUID: TRUE
-- Looking for gz-utils2 -- found version 2.2.1
-- Searching for dependencies of gz-utils2
-- Searching for <gz-utils2> component [cli]
-- Looking for gz-utils2-cli -- found version 2.2.1
-- Searching for dependencies of gz-utils2-cli
-- Looking for gz-msgs10 -- found version 10.3.2
-- Searching for dependencies of gz-msgs10
-- Looking for gz-math7 -- found version 7.5.2
-- Searching for dependencies of gz-math7
-- Checking for module 'tinyxml2'
--   Found tinyxml2, version 11.0.0
-- Found Python3: /Users/mustafacayci/Documents/Projects/px4/venv/bin/python3.14 (found version "3.14.2") found components: Interpreter
-- Found Protobuf: /opt/homebrew/lib/libprotobuf.dylib (found version "6.33.2")
-- Looking for gz-sim8 -- found version 8.10.0
-- Searching for dependencies of gz-sim8
-- Looking for sdformat14 -- found version 14.8.0
-- Searching for dependencies of sdformat14
-- Looking for gz-plugin2 -- found version 2.0.4
-- Searching for dependencies of gz-plugin2
-- Searching for <gz-plugin2> component [loader]
-- Looking for gz-plugin2-loader -- found version 2.0.4
-- Searching for dependencies of gz-plugin2-loader
-- Searching for <gz-plugin2> component [register]
-- Looking for gz-plugin2-register -- found version 2.0.4
-- Searching for dependencies of gz-plugin2-register
-- Searching for <gz-transport13> component [log]
-- Looking for gz-transport13-log -- found version 13.5.0
-- Searching for dependencies of gz-transport13-log
-- Searching for <gz-transport13> component [parameters]
-- Looking for gz-transport13-parameters -- found version 13.5.0
-- Searching for dependencies of gz-transport13-parameters
-- Looking for gz-common5 -- found version 5.7.1
-- Searching for dependencies of gz-common5
-- Looking for dlfcn.h - found
-- Looking for libdl - found
-- Found DL: TRUE
-- Searching for <gz-common5> component [av]
-- Looking for gz-common5-av -- found version 5.7.1
-- Searching for dependencies of gz-common5-av
-- Checking for module 'libswscale'
--   Found libswscale, version 9.1.100
-- Found SWSCALE: TRUE
-- Checking for module 'libavdevice >= 56.4.100'
--   Found libavdevice, version 62.1.100
-- Found AVDEVICE: TRUE (Required is at least version "56.4.100")
-- Checking for module 'libavformat'
--   Found libavformat, version 62.3.100
-- Found AVFORMAT: TRUE
-- Checking for module 'libavcodec'
--   Found libavcodec, version 62.11.100
-- Found AVCODEC: TRUE
-- Checking for module 'libavutil'
--   Found libavutil, version 60.8.100
-- Found AVUTIL: TRUE
-- Searching for <gz-common5> component [events]
-- Looking for gz-common5-events -- found version 5.7.1
-- Searching for dependencies of gz-common5-events
-- Searching for <gz-common5> component [graphics]
-- Looking for gz-common5-graphics -- found version 5.7.1
-- Searching for dependencies of gz-common5-graphics
-- Found GzAssimp: TRUE (found version "6.0.2")
-- Searching for <gz-common5> component [io]
-- Looking for gz-common5-io -- found version 5.7.1
-- Searching for dependencies of gz-common5-io
-- Searching for <gz-common5> component [profiler]
-- Looking for gz-common5-profiler -- found version 5.7.1
-- Searching for dependencies of gz-common5-profiler
-- Looking for gz-fuel_tools9 -- found version 9.1.1
-- Searching for dependencies of gz-fuel_tools9
-- Found CURL: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/lib/libcurl.tbd (found version "8.7.1")
-- Checking for module 'jsoncpp'
--   Found jsoncpp, version 1.9.6
-- Found JSONCPP: TRUE
-- Checking for module 'yaml-0.1'
--   Found yaml-0.1, version 0.2.5
-- Found YAML: TRUE
-- Checking for module 'libzip'
--   Found libzip, version 1.11.4
-- Found ZIP: TRUE
-- Searching for <gz-common5> component [testing]
-- Looking for gz-common5-testing -- found version 5.7.1
-- Searching for dependencies of gz-common5-testing
-- Looking for gz-gui8 -- found version 8.4.0
-- Searching for dependencies of gz-gui8
-- Looking for gz-rendering8 -- found version 8.2.3
-- Searching for dependencies of gz-rendering8
-- Searching for <gz-math7> component [eigen3]
-- Looking for gz-math7-eigen3 -- found version 7.5.2
-- Searching for dependencies of gz-math7-eigen3
-- Checking for module 'eigen3'
--   Found eigen3, version 5.0.1
-- Searching for <gz-common5> component [geospatial]
-- Looking for gz-common5-geospatial -- found version 5.7.1
-- Searching for dependencies of gz-common5-geospatial
-- Searching for <gz-plugin2> component [all]
-- Looking for all libraries of gz-plugin2 -- found version 2.0.4
-- Looking for gz-physics7 -- found version 7.6.0
-- Searching for dependencies of gz-physics7
-- Searching for <gz-physics7> component [heightmap]
-- Looking for gz-physics7-heightmap -- found version 7.6.0
-- Searching for dependencies of gz-physics7-heightmap
-- Searching for <gz-physics7> component [mesh]
-- Looking for gz-physics7-mesh -- found version 7.6.0
-- Searching for dependencies of gz-physics7-mesh
-- Searching for <gz-physics7> component [sdf]
-- Looking for gz-physics7-sdf -- found version 7.6.0
-- Searching for dependencies of gz-physics7-sdf
-- Looking for gz-sensors8 -- found version 8.2.2
-- Searching for dependencies of gz-sensors8
-- Searching for <gz-sensors8> component [air_pressure]
-- Looking for gz-sensors8-air_pressure -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-air_pressure
-- Searching for <gz-sensors8> component [air_speed]
-- Looking for gz-sensors8-air_speed -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-air_speed
-- Searching for <gz-sensors8> component [altimeter]
-- Looking for gz-sensors8-altimeter -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-altimeter
-- Searching for <gz-sensors8> component [imu]
-- Looking for gz-sensors8-imu -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-imu
-- Searching for <gz-sensors8> component [force_torque]
-- Looking for gz-sensors8-force_torque -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-force_torque
-- Searching for <gz-sensors8> component [logical_camera]
-- Looking for gz-sensors8-logical_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-logical_camera
-- Searching for <gz-sensors8> component [magnetometer]
-- Looking for gz-sensors8-magnetometer -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-magnetometer
-- Searching for <gz-sensors8> component [navsat]
-- Looking for gz-sensors8-navsat -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-navsat
-- Searching for <gz-sensors8> component [dvl]
-- Looking for gz-sensors8-dvl -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-dvl
-- Searching for <gz-sensors8> component [rendering]
-- Looking for gz-sensors8-rendering -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-rendering
-- Searching for <gz-sensors8> component [lidar]
-- Looking for gz-sensors8-lidar -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-lidar
-- Searching for <gz-sensors8> component [gpu_lidar]
-- Looking for gz-sensors8-gpu_lidar -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-gpu_lidar
-- Searching for <gz-sensors8> component [camera]
-- Looking for gz-sensors8-camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-camera
-- Searching for <gz-sensors8> component [boundingbox_camera]
-- Looking for gz-sensors8-boundingbox_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-boundingbox_camera
-- Searching for <gz-sensors8> component [segmentation_camera]
-- Looking for gz-sensors8-segmentation_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-segmentation_camera
-- Searching for <gz-sensors8> component [depth_camera]
-- Looking for gz-sensors8-depth_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-depth_camera
-- Searching for <gz-sensors8> component [rgbd_camera]
-- Looking for gz-sensors8-rgbd_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-rgbd_camera
-- Searching for <gz-sensors8> component [thermal_camera]
-- Looking for gz-sensors8-thermal_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-thermal_camera
-- Searching for <gz-sensors8> component [wide_angle_camera]
-- Looking for gz-sensors8-wide_angle_camera -- found version 8.2.2
-- Searching for dependencies of gz-sensors8-wide_angle_camera
-- Found OpenCV: /opt/homebrew/Cellar/opencv/4.12.0_19 (found version "4.12.0")
-- Found OpenCV: /opt/homebrew/Cellar/opencv/4.12.0_19 (found version "4.12.0") found components: core imgproc
-- Found PkgConfig: /opt/homebrew/bin/pkg-config (found version "2.5.1")
-- Checking for module 'gstreamer-1.0'
--   Found gstreamer-1.0, version 1.26.10
-- Checking for module 'gstreamer-app-1.0'
--   Found gstreamer-app-1.0, version 1.26.10
-- Found Java: /Library/Java/JavaVirtualMachines/temurin-25.jdk/Contents/Home/bin/java (found version "25.0.1")
-- ROMFS: ROMFS/px4fmu_common
-- Configuring done (4.4s)
-- Generating done (0.4s)
-- Build files have been written to: /Users/mustafacayci/Documents/Projects/px4/PX4-Autopilot/build/px4_sitl_default
ninja: error: unknown target 'gazebo-classic_iris'
make: *** [px4_sitl] Error 1
Classic Gazebo has been replaced, so support will be tricky, unfortunately. I personally still have it running in a Ubuntu 20.04 Virtualbox image, for when I need it.
If developers using Apple want to chime in and help maintain this, that’s good, otherwise, consider it abandoned.
Does new Gazebo not work for you?
@JulianOes Hello Julian, I have five developers and I am trying to establish development environments for each. Today as you know I installed and configured on Ubuntu 22.04 in Jetson Orin Nano except QGroundControl (That is another issue.) but if all developers connect to that environment at the same, I am afraid it is not going to scale. That is the problem I am trying to solve. If you have any suggestions, please do share with me.
Thank you,
Mustafa
Are you saying that one option is to create a Virtual Environment in our MacBooks and install PX4 and QGroundControl on the Virtual Environment? Thanks for your confirmation.
Mustafa
What about using new Gazebo instead of Gazebo classic that has been deprecated several years ago (by OSRF not PX4, we are just downstream of that decision).
