Px4 v1.12.3 on ubuntu 22.04 and gazebo11
I have a problem starting the px4 v1.12.3 with gazebo11 on ubuntu 22.04.
input:
on ubuntu 20.04: everthing works, no problems.
on ubuntu 22.04:
  1. building the code v1.12.3 is fine.
  2. building v1.12.3 with jmavsim simulation is fine.
  3. building v1.12.3 with gazebo11 simulation is problematic.
$ make px4_sitl_default gazebo
the build stops in the middle and the pc crashes (need to reboot)
I have already performed the ./setup/ubuntu.sh > install gazebo harmonics
then I have removed harmonics and installed gazebo11:
$ sudo apt remove gz-harmonic
$ sudo apt install aptitude
$ sudo aptitude install gazebo libgazebo11 libgazebo-dev
any help please?
[0/11] git submodule Tools/sitl_gazebo
[6/11] Performing configure step for 'sitl_gazebo'
-- install-prefix: /usr/local
-- cmake build type: RelWithDebInfo
-- The C compiler identification is GNU 9.5.0
-- The CXX compiler identification is GNU 9.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Performing Test COMPILER_SUPPORTS_CXX17
-- Performing Test COMPILER_SUPPORTS_CXX17 - Success
-- Performing Test COMPILER_SUPPORTS_CXX14
-- Performing Test COMPILER_SUPPORTS_CXX14 - Success
-- Performing Test COMPILER_SUPPORTS_CXX11
-- Performing Test COMPILER_SUPPORTS_CXX11 - Success
-- Performing Test COMPILER_SUPPORTS_CXX0X
-- Performing Test COMPILER_SUPPORTS_CXX0X - Success
-- Using C++17 standard
-- ccache enabled (export CCACHE_DISABLE=1 to disable)
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found suitable version "1.74.0", minimum required is "1.58") found components: system thread filesystem
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'bullet>=2.82'
--   Found bullet, version 3.05
-- Found fcl: /usr/include (found suitable version "0.7.0", minimum required is "0.5.0")
-- Found assimp: /usr/include (found version "5.2.0")
-- Found DART: /usr/include (Required is at least version "6.6") found components: dart
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found suitable version "1.74.0", minimum required is "1.40.0") found components: thread system filesystem program_options regex iostreams date_time
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so (found version "3.12.4")
-- Looking for ignition-math6 -- found version 6.15.1
-- Searching for dependencies of ignition-math6
-- Looking for OGRE...
-- OGRE_PREFIX_WATCH changed.
-- Checking for module 'OGRE'
--   Found OGRE, version 1.9.0
-- Found OGRE: optimized;/usr/lib/x86_64-linux-gnu/libOgreMain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreMain.so
-- Looking for OGRE_Paging...
-- Found OGRE_Paging: optimized;/usr/lib/x86_64-linux-gnu/libOgrePaging.so;debug;/usr/lib/x86_64-linux-gnu/libOgrePaging.so
-- Found OGRE_Terrain: optimized;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so;debug;/usr/lib/x86_64-linux-gnu/libOgreTerrain.so
-- Found OGRE_Property: optimized;/usr/lib/x86_64-linux-gnu/libOgreProperty.so;debug;/usr/lib/x86_64-linux-gnu/libOgreProperty.so
-- Found OGRE_RTShaderSystem: optimized;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so;debug;/usr/lib/x86_64-linux-gnu/libOgreRTShaderSystem.so
-- Looking for OGRE_Volume...
-- Found OGRE_Volume: optimized;/usr/lib/x86_64-linux-gnu/libOgreVolume.so;debug;/usr/lib/x86_64-linux-gnu/libOgreVolume.so
-- Found OGRE_Overlay: optimized;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so;debug;/usr/lib/x86_64-linux-gnu/libOgreOverlay.so
-- Looking for ignition-transport8 -- found version 8.2.1
-- Searching for dependencies of ignition-transport8
-- Found Protobuf: /usr/lib/x86_64-linux-gnu/libprotobuf.so (found suitable version "3.12.4", minimum required is "3")
-- Config-file not installed for ZeroMQ -- checking for pkg-config
-- Checking for module 'libzmq >= 4'
--   Found libzmq , version 4.3.4
-- Found ZeroMQ: TRUE (Required is at least version "4")
-- Checking for module 'uuid'
--   Found uuid, version 2.37.2
-- Found UUID: TRUE
-- Looking for ignition-msgs5 -- found version 5.8.1
-- Searching for dependencies of ignition-msgs5
-- Checking for module 'tinyxml2'
--   Found tinyxml2, version 9.0.0
-- Looking for ignition-common3 -- found version 3.14.0
-- Searching for dependencies of ignition-common3
-- Looking for dlfcn.h - found
-- Looking for libdl - found
-- Found DL: TRUE
-- Found tinyobjloader: /usr/lib/x86_64-linux-gnu/cmake/tinyobjloader/tinyobjloader-config.cmake (found version "2.0.0")
-- Searching for <ignition-common3> component [graphics]
-- Looking for ignition-common3-graphics -- found version 3.14.0
-- Searching for dependencies of ignition-common3-graphics
-- Looking for ignition-fuel_tools4 -- found version 4.4.0
-- Searching for dependencies of ignition-fuel_tools4
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.81.0")
-- Checking for module 'jsoncpp'
--   Found jsoncpp, version 1.9.5
-- Found JSONCPP: TRUE
-- Checking for module 'yaml-0.1'
--   Found yaml-0.1, version 0.2.2
-- Found YAML: TRUE
-- Checking for module 'libzip'
--   Found libzip, version 1.7.3
-- Found ZIP: TRUE
-- Checking for one of the modules 'glib-2.0'
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.10.12", minimum required is "3")
-- Found OpenCV: /usr (found version "4.5.4")
-- Found TinyXML: /usr/lib/x86_64-linux-gnu/libtinyxml.so
-- Checking for module 'gstreamer-1.0 >= 1.0'
--   Found gstreamer-1.0 , version 1.20.3
-- Checking for module 'gstreamer-base-1.0 >= 1.0'
--   Found gstreamer-base-1.0 , version 1.20.3
-- Checking for module 'gstreamer-app-1.0 >= 1.0'
--   Found gstreamer-app-1.0 , version 1.20.1
-- Found GStreamer: GSTREAMER_INCLUDE_DIRS;GSTREAMER_LIBRARIES;GSTREAMER_VERSION;GSTREAMER_BASE_INCLUDE_DIRS;GSTREAMER_BASE_LIBRARIES (Required is at least version "1.0")
-- Found MAVLink: /home/ava/repos/mypx4/Firmware/mavlink/include (found version "2.0")
-- catkin DISABLED
-- Checking for module 'protobuf'
--   Found protobuf, version 3.12.4
-- Gazebo version: 11.10
-- Found GStreamer: adding gst_camera_plugin
-- Found GStreamer: adding gst_video_stream_widget
-- Configuring done
-- Generating done
-- Build files have been written to: /home/ava/repos/mypx4/Firmware/build/px4_sitl_default/build_gazebo
[7/11] Performing build step for 'sitl_gazebo'
[25/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/c920/c920.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/c920/c920.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/c920/c920.sdf
[26/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/tailsitter/tailsitter.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/tailsitter/tailsitter.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/tailsitter/tailsitter.sdf
[27/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/3DR_gps_mag/3DR_gps_mag.sdf
[28/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/depth_camera/depth_camera.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/depth_camera/depth_camera.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/depth_camera/depth_camera.sdf
[29/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/sf10a/sf10a.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/sf10a/sf10a.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/sf10a/sf10a.sdf
[31/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/boat/boat.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/boat/boat.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/boat/boat.sdf
[32/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/standard_vtol/standard_vtol.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/standard_vtol/standard_vtol.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/standard_vtol/standard_vtol.sdf
[33/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/px4flow/px4flow.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/px4flow/px4flow.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/px4flow/px4flow.sdf
[36/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/rover/rover.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/rover/rover.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/rover/rover.sdf
[37/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/iris/iris.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/iris/iris.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/iris/iris.sdf
[38/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/tiltrotor/tiltrotor.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/tiltrotor/tiltrotor.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/tiltrotor/tiltrotor.sdf
[39/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/r200/r200.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/r200/r200.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/r200/r200.sdf
[40/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/pixhawk/pixhawk.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/pixhawk/pixhawk.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/pixhawk/pixhawk.sdf
[41/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/mb1240-xl-ez4/mb1240-xl-ez4.sdf
[42/126] Generating /home/ava/repos/mypx4/Firmware/Tool...gazebo/models/standard_vtol_drop/standard_vtol_drop.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/standard_vtol_drop/standard_vtol_drop.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/standard_vtol_drop/standard_vtol_drop.sdf
[43/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/cloudship/cloudship.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/cloudship/cloudship.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/cloudship/cloudship.sdf
[44/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/typhoon_h480/typhoon_h480.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/typhoon_h480/typhoon_h480.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/typhoon_h480/typhoon_h480.sdf
[45/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/plane/plane.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/plane/plane.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/plane/plane.sdf
[47/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/r1_rover/r1_rover.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/r1_rover/r1_rover.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/r1_rover/r1_rover.sdf
[49/126] Generating /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/matrice_100/matrice_100.sdf
/home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/matrice_100/matrice_100.sdf.jinja -> /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/models/matrice_100/matrice_100.sdf
[59/126] Building CXX object CMakeFiles/gazebo_mavlink_interface.dir/src/mavlink_interface.cpp.o
In file included from /usr/include/boost/smart_ptr/detail/sp_thread_sleep.hpp:22,
                 from /usr/include/boost/smart_ptr/detail/yield_k.hpp:23,
                 from /usr/include/boost/smart_ptr/detail/spinlock_gcc_atomic.hpp:14,
                 from /usr/include/boost/smart_ptr/detail/spinlock.hpp:42,
                 from /usr/include/boost/smart_ptr/detail/spinlock_pool.hpp:25,
                 from /usr/include/boost/smart_ptr/shared_ptr.hpp:29,
                 from /usr/include/boost/shared_ptr.hpp:17,
                 from /usr/include/boost/date_time/time_clock.hpp:17,
                 from /usr/include/boost/date_time/posix_time/posix_time_types.hpp:10,
                 from /usr/include/boost/asio/time_traits.hpp:23,
                 from /usr/include/boost/asio/detail/timer_queue_ptime.hpp:22,
                 from /usr/include/boost/asio/detail/deadline_timer_service.hpp:29,
                 from /usr/include/boost/asio/basic_deadline_timer.hpp:25,
                 from /usr/include/boost/asio.hpp:25,
                 from /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/include/mavlink_interface.h:36,
                 from /home/ava/repos/mypx4/Firmware/Tools/sitl_gazebo/src/mavlink_interface.cpp:1:
/usr/include/boost/bind.hpp:36:1: note: #pragma message: The practice of declaring the Bind placeholders (_1, _2, ...) in the global namespace is deprecated. Please use <boost/bind/bind.hpp> + using namespace boost::placeholders, or define BOOST_BIND_GLOBAL_PLACEHOLDERS to retain the current behavior.
   36 | BOOST_PRAGMA_MESSAGE(
[63/126] Building CXX object CMakeFiles/gazebo_video_st...widget.dir/include/moc_gazebo_video_stream_widget.cpp.o
new input:
  1. cloning the latest px4 v1.15.* , and then using gazebo-classic (gazebo11), this would work with no problems. (so I believe my gazebo11 is working normally and was installed correctly).
  2. I have used docker images to build: px4io/px4-dev-simulation-focal , the build stops at the same point with error.
[61/126] Building CXX object CMakeFiles/gazebo_...ir/include/moc_gazebo_video_stream_widget.cpp.o
Note that I have used the same docker image and the same code px4v1.12.3 on a local ubutnu20.04 OS, it it works with no problems.
  1. I have checked this, but I see that cpp17 is used in my case and the problem is not solved: https://de.mathworks.com/matlabcentral/answers/1792100-unable-to-build-gazebo-co-sim-plugin-on-ubuntu-22-04-jammy-machine-with-gazebo-11?s_tid=answers_rc1-1_p1_BOTH
@JulianOes I would appreciate your help :slight_smile:
I just don’t hassle and use Ubuntu 20.04 on all machines. Maybe try gazebo 9 if want to fight.
I’d have to tinker with it myself. I’m afraid I don’t have time for that though, and I think my time is better invested porting what’s missing to new Gazebo instead.
I don’t recall exactly because v1.12 was a long time ago, but seems like it might be too early to use Gazebo 11.
Try following the guides for the version of PX4 you are trying, if you ran ubuntu.sh it should have installed Gazebo 9, if you installed Gazebo 11 on top of that, then there might be conflicts you want to resolve there.
