Why are the low-pass filtered members of sensor_accel and sensor_gyro not propagated to sensor_combined?
It seems to me that the IMU_ACCEL_CUTOFF and IMU_GYRO_CUTOFF have no effect because the integral_x,y,z members are propagated into sensor_combined instead of the filtered x,y,z members.
I am actually looking into this and, from what I see in the comments, it seems that the integral values are preferred:
if (accel_report.integral_dt != 0) {
* Using data that has been integrated in the driver before downsampling is preferred
* becasue it reduces aliasing errors. Correct the raw sensor data for scale factor errors
* and offsets due to temperature variation. It is assumed that any filtering of input
* data required is performed in the sensor driver, preferably before downsampling.
} else {
// using the value instead of the integral (the integral is the prefered choice)
// Correct each sensor for temperature effects
// Filtering and/or downsampling of temperature should be performed in the driver layer
Filtering might have happened anyway in the driver layer tho?
