I am trying to log my custom uORB message in a simulation using ROS. The logger.cpp looks in
PX4_ROOTFSDIR "/fs/microsd/etc/logging/logger_topics.txt"
for the file logger_topics.txt. The problem is I tried to add such a file in
~/.ros/rootfs/fs/microsd/etc/loggin/...
and in
PX4 /build_posix_sitl_default/tmp/rootfs/fs/etc/logging
but none works. Does anyone know where to add the logger_topics.txt so that it can be found?
Best regards
Nils
I believe it should be in Firmware/build_posix_sitl_default/tmp/rootfs/fs/microsd/etc/logging/logger_topics.txt.
I figured out where the problem is. The correct implementation for in the logger_topics.txt is, for example,
att_pos_mocap
instead of
<att_pos_mocap>
I have another problem. When I try to use pyulog to transform my ulg data to csv I got the follwoing error:
File "/home/hippoc/.local/bin/ulog2csv", line 11, in <module>
sys.exit(main())
File "/home/hippoc/.local/lib/python2.7/site-packages/pyulog/ulog2csv.py", line 43, in main
convert_ulog2csv(args.filename, args.messages, args.output, args.delimiter)
File "/home/hippoc/.local/lib/python2.7/site-packages/pyulog/ulog2csv.py", line 60, in convert_ulog2csv
ulog = ULog(ulog_file_name, msg_filter)
File "/home/hippoc/.local/lib/python2.7/site-packages/pyulog/core.py", line 97, in __init__
self._load_file(file_name, message_name_filter_list)
File "/home/hippoc/.local/lib/python2.7/site-packages/pyulog/core.py", line 377, in _load_file
self._read_file_definitions()
File "/home/hippoc/.local/lib/python2.7/site-packages/pyulog/core.py", line 402, in _read_file_definitions
header.initialize(data)
File "/home/hippoc/.local/lib/python2.7/site-packages/pyulog/core.py", line 213, in initialize
self.msg_size, self.msg_type = ULog._unpack_ushort_byte(data)
struct.error: unpack requires a string argument of length 3
My message definition looks like
# Logging data for HippoCampus
float32 x # in meters NED
float32 y # in meters NED
float32 z # in meters NED
float32 xd # in meters/sec
float32 yd # in meters/sec
float32 zd # in meters/sec
Does anyone know why I get the error?
I already found my mistake. I have done something wrong in the code thus the message which I tried to logg hasn’t been published. Now it works.
