Lifting off on windy days
Hello all,
I am having the “Preflight Fail: check Airspeed Cal or Pitot” error very often on windy days. The workaround I do is just yawing 90 degrees the aircraft so that it has side wind at takeoff, which is quite dirty solution especially in stormy days.
I noticed that the preflight airspeed limit is a hard-coded 4 m/s value in airspeedCheck.cpp as following:
 * Check if airspeed is higher than 4m/s (accepted max) while the vehicle is landed / not flying
 * Negative and positive offsets are considered. Do not check anymore while arming because pitot cover
 * might have been removed.
if (fabsf(airspeed.indicated_airspeed_m_s) > 4.0f && prearm) {
	if (report_fail) {
		mavlink_log_critical(mavlink_log_pub, "Preflight Fail: check Airspeed Cal or Pitot");
	present = true;
	success = false;
	goto out;
Wouldn’t it be handy to put a user-accesible variable to set the airspeed limit to arm?
Thanks,
Ozan
Or you can cancel the pre-flight airspeed check by setting the parameters
@xdwgood, thanks for the reply.
Do you mean setting CBRK_AIRSPD_CHK = 162128? Doesn’t it correspond to VTOL without an airspeed sensor?
Does not it disable using airspeed totally?
I did address it in Airspeed preflight checks update by sfuhrer · Pull Request #14254 · PX4/PX4-Autopilot · GitHub, though it hasn’t been merged yet. I will push more for it, should help that I’m not the only one hitting this problem.
In the PR I introduce a new parameter, COM_ARM_ARSP_EN, which could be set to false to disable a check for max airspeed for takeoff.
Feel free to comment on the PR, this way we could get more attention to get it in faster.
