Hi there,
is there already support for non- IRLock precision landing ? I would like to perform precision landing by providing the target position over mavlink/mavros. At the moment the landing_target_estimator seams to work only with IR lock DD. Or is there a way to override the input coordinates?
If you have the target position externally, you can feed it to PX4 by sending LANDING_TARGET messages. You can see in malvink_receiver.cpp how they are received and published for the precision landing flight mode:
Hi @Nicolas,
thanks for your prompt reply and helpful input.
At the moment I am trying to send those messages over mavros. Somehow is still not working. Did you ever tested this? I was already considering performing the precision landing over off-board mode.
I will post the results once I have managed to get it working(if it works ;-).
Thanks once again.
Which part isn’t working? Are the messages received by PX4? You should see messages on the landing_target_pose topic in your .ulg. If you see messages in irlock_report, then the message you’re sending is not filled in correctly.
Hi Nicolas,
in the ulg or in mavlink inspektor I dont see any landing messages related.
This is what I have done so far:
under my mavros build …/mavros/launch/px4_config.yaml # landing_target landing_target: listen_lt: true # changed here to true
after that I am able to see that there is two topics generated by mavros and the following messages are displayed. [ INFO] [1599642890.951102369]: Listen to landing_target transform landing_target -> camera_center [ INFO] [1599642890.951322749]: Plugin landing_target initialized
made sure the plugin from Px4 the landing_target_estimator is started
pxh> landing_target_estimator start
INFO [landing_target_estimator] already running
So I assume the messages are never reaching px4. I tried to publish messages to both mavros topics but no reaction from the px4 side. Which is the right topic from mavros to publish the landing target coordinates?
Many thanks !
Hi @Nicolas,
many thanks for your help. I have debugged the mavros_extras plugin … this one starts publishing to /mavros/landing_target/raw once my tf becomes available … so far so good.
I can see the messages in /mavros/landing_target/raw they are ok and the low-level landing_target() is also called.
Under mavlink inspector I can’t still see any messages related to LANDING.
Under Px4
[ WARN] [1599663330.075529991, 875.932000000]: CMD: Unexpected command 176, result 0
WARN [mc_pos_control] Auto activation failed with error: Activation Failed
WARN [navigator] Resetting landing position to current position
WARN [navigator] Lost landing target while landing (horizontal approach).
INFO [navigator] Climbing to search altitude.
WARN [navigator] Lost landing target while landing (descending).
WARN [navigator] Falling back to normal land.
INFO [commander] Landing detected
The behavior: The drone returns to the starting position and starts descending and once it loses the apriltag starts going up and down.
So something is working. Just not as it should.
Looks like something is happening indeed. If landing on the tag works as expected until it loses it, it might simply be a question of setting an appropriate final approach altitude for your use case:
Hi Nicolas,
I found the issue. Seems like under lt.frame under mavros/mavros_extras/src/plugins/landing_target.cpp is not being set proper.
even it is set to “LOCAL_NED” = 2 and under px4 mavlink should be MAV_FRAME_LOCAL_NED = 1 in order be published. The landing_target.position_valid is valid.
So i changed some things and now I have uOrb topic outputing
pxh> listener landing_target_pose
I will keep digging. But something is not working as it should.
Either way I just also noticed that only pose is being sent. Orientation is missing. Or am I missing something here ?
Did you ever tried this mode with external target position input ?
So this, works with both covariance, relative position and absolute.Looks very good. This is how it should look like for the vision based approach too. I assume at least.
Obviously from my previous message this is being wrongly posted. Or?
I assume that this mavros_extras plugin is not working proper…
PS: @TSC21 hey nuno can you perhaps give your input here as well? Obrigado!
Hi @prem_chittireddy,
we currently fly only off-board mode. We do not use any of the internal features for automatic landing.
For the landing we use Apriltags detection together with a self developed algorithm for automate the landing.
