Landing Bounce in Auto and Position Mode
I have a Quadcopter is a 4kg / 16 inch prop [Frame Size: 640mm and generic model] [Hardware : Pixhawk4 / Firmware: 1.11.3 ]. When I try to land in Auto and Position, Quad is bouncing one time and after landing completed. Which parameters should I change to solve this issue. Is there a problem with the rate controller [Set Point is twitchy].Thanks for supports.
Flight Logs Here
https://logs.px4.io/plot_app?log=56504017-6e9d-44b3-9246-02534be3063d
https://logs.px4.io/plot_app?log=abd94ada-8bf5-4165-9632-d996aa3e67ea
Video:
https://drive.google.com/file/d/17OA9SbS8mItV-1cszt_WzzSMbi91JLMx/view?usp=sharing
This is the Hover Flight Test Log Data. Do you think the problem is caused by vibration?
https://logs.px4.io/plot_app?log=bd8a42df-53cf-4b51-998c-3408729edcad
@mehmetydz87 can you please open access to the video link you shared? something like “anyone with the link can view” would be enough.
Sorry I changed the shared options o f video.
I think this problem is caused by vibration. I made changes to the Pixhawk mechanical connection. I removed vibration damper plate and used the 3M Foam Pad & Frame Vibration Damper Plate [FOXTECH HOVER 1 Frame with T-Motor U5 frame]. I made tests on my test system. I did not see this problem on my flight today, as the vibration has decreased [let’s say better] and after recalibrating the Rate Controller [Parallel Form Used].
https://logs.px4.io/plot_app?log=97e4fb0d-495f-4088-b025-068cb33c60b0
This is probably the incresed pressure due to propeller air flow hitting the ground.
See this for how to tune the ekf to reject it:
