Hello there ~ I was trying to build qgrouncontrol for android but this error appear
any idea how to fix this? thanks
QGC has been updated for the Android compatability which requires QT 5.15.2.
Navigate to the android.pri file in qt creator and comment out lines 10-19. I posted an issue on GitHub because that should only be a temporary fix. I encountered this issue the other day as well.
its’s still not working, I’ve been trying to clean it and rebuild it, but it’s still give the same result, but thanks for the suggestion tho, appreciate it
I already use 5.15.2, with android ndk 21
you can disable the make install step, however, if you do, you have to move the specific architectures that were built to their respective folders within the build folder.
done, but it seems we create another error
what did I do? I copy all the files from armeabi-v7a to staging/android-build/libs/armeabi-v7a, and then click at build button, so, what went wrong?
