Issue with Constantly Spinning Motor on Crazyflie 2.1 After Flashing PX4 Firmware
Hello everyone
I recently flashed the PX4 firmware on my Crazyflie 2.1 following the instructions from the PX4 documentation. However, after completing the process, I encountered a problem where one of the motors spins continuously as soon as the drone is powered on.
Here are the steps I followed:
  1. Installed the required tools:
    sudo apt-get update
    sudo apt-get install git python3 python3-pip python3-venv cmake build-essential gcc-arm-none-eabi
    git clone GitHub - PX4/PX4-Autopilot: PX4 Autopilot Software · GitHub --recursive
    cd PX4-Autopilot
    bash ./Tools/setup/ubuntu.sh
    Added the path to .bashrc:
    export PATH=$PATH:/home/bob/.local/bin
    source ~/.bashrc
  2. Cloned PX4 bootloader and created symbolic link to Python 3:
    git clone GitHub - PX4/PX4-Bootloader: PX4 Bootloader for PX4FMU, PX4IO and PX4FLOW · GitHub --recurse-submodules
    cd Bootloader
    sudo ln -s /usr/bin/python3 /usr/bin/python
    make crazyflie21_bl
  3. Downloaded PX4 Autopilot source and compiled:
    cd ../PX4-Autopilot/
    make bitcraze_crazyflie21_default upload
  4. Put the Crazyflie 2.1 in DFU mode and installed dfu-util:
    sudo apt-get update
    sudo apt-get install dfu-util
  5. Flashed the bootloader:
    sudo dfu-util -d 0483:df11 -a 0 -s 0x08000000 -D ./build/bitcraze_crazyflie21_default/bitcraze_crazyflie21_default.bin
  6. Allowed USB port access for Crazyradio:
    sudo groupadd plugdev
    sudo usermod -a -G plugdev $USER
    cat <<EOF | sudo tee /etc/udev/rules.d/99-bitcraze.rules > /dev/null
    Crazyradio (normal operation)
    SUBSYSTEM==“usb”, ATTRS{idVendor}==“1915”, ATTRS{idProduct}==“7777”, MODE=“0664”, GROUP=“plugdev”
    Bootloader
    SUBSYSTEM==“usb”, ATTRS{idVendor}==“1915”, ATTRS{idProduct}==“0101”, MODE=“0664”, GROUP=“plugdev”
    Crazyflie (over USB)
    SUBSYSTEM==“usb”, ATTRS{idVendor}==“0483”, ATTRS{idProduct}==“5740”, MODE=“0664”, GROUP=“plugdev”
    EOF
    sudo udevadm control --reload-rules
    sudo udevadm trigger
  7. Compiled and uploaded the firmware to the Crazyflie:
After following these steps, one of the motors starts spinning continuously once the Crazyflie is powered on. I have verified the hardware connections and retried the steps multiple times but the issue persists.
Questions:
  • Has anyone experienced similar issues with Crazyflie 2.1 and PX4?
  • Are there any specific parameters or configurations that need adjustment to resolve this?
  • Could this be a firmware bug or a hardware compatibility issue?
Any help or guidance would be greatly appreciated. Thank you!
Hi I am experiencing the exact issue. Did you happen to find a solution?
Hi
no I don’t have a solution
YES, I meet the same problem.
One of the motor started to spin.
And the QGC can not connect to crazyflie.
Do you have any solution?
