Hi everyone,
I have downloaded a logfile of one of my SITL flights from QGC and loaded it into the Flight Review Tool, and now I need to import it to matlab to study properly the graphs… is it possible? And could i obtain the RPMs of each one of my motors?
Yes! There are some commands that you can use in matlab 2020 or newer in the UAV toolbox. If you don`t have it you may use this little matlab program I created that converts the ulg file into a matlab file.
Once you run it (load the ulg file then save it) you will end up with a mat file containing all the recorded flight data in the “datatable” variable.
Hope this helps!
Sean Baz
