New progress: I have added a cable_suspended payload to the iris model with mass that is fixed to the center of the iris drone with a ball joint, however, a problem came that the GPS can not be used when trying to takeoff and the reason seems to relate to that the GPS module is superposed with the ball joint. Has anyone encountered such problem?
Solved this by using iris model. Was using iris_fpv_cam.
May I ask how did you build the quadcopter payload system?
I added a stick with a cyclinder at its one end and with the other end connected to the Iris drone model bottom. The model cannot retract the payload, and the stick is not elastic as an ideal cable, either
As for how to do, check many existing tutorials about modification of SDF. file of robots
Thanks for your reply.
