How to set up an Octocopter Coaxial frame in PX4/QGroundControl
I’m trying to build an Octocopter coaxial frame (16 motors, 8 arms, two motors per arm) and I plan to use PX4 firmware with QGroundControl. I am using Pixhawk 6C, so there are 16 pins on both Main and Aux PWM.
I’m a bit unsure how to set up this geometry in the PX4 or frame configuration.
  • Which airframe type should I select in QGroundControl, as I can’t find this airframe type?
  • Any tips or documentation on motor order and rotation direction for coaxial setup?
Thanks in advance for your help!
