Hi, I am having problems setting up my controller on the Pixhawk 6c… I get this when I calibrate the radio
Radio not ready (turn on the controller)
Any help would be appreciated.
Sounds like the radio is not connected as it should. The radio and the receiver might not be connected properly?
Some more information about what controller you are using might be of help.
You need to use the newest code. Flash main/master from QGC. The release version won’t work.
