How to run my gazebo plugin in sitl with gz_x500?
// UwbPosition.hpp
#pragma once
#include <gz/sim/System.hh>
#include <gz/transport/Node.hh>
#include <gz/sim/Model.hh>
#include <gz/plugin/Register.hh>
#include <gz/common/Console.hh>
#include <gz/sim/components/Pose.hh>
#include <gz/sim/components/World.hh>
#include <gz/msgs/pose_v.pb.h>
#include <gz/msgs/pose.pb.h>
#include <termios.h>
#include <fcntl.h>
#include <unistd.h>
#include <chrono>
#include <iostream>
#include <string>
#include <random>
namespace custom
class UwbPositionPlugin:
	public gz::sim::System,
	public gz::sim::ISystemPreUpdate,
	public gz::sim::ISystemPostUpdate
public:
	// called when plugin is loaded and configured from SDF
	void Configure(const gz::sim::Entity &_entity,
		const std::shared_ptr<const sdf::Element> &_sdf,
		gz::sim::EntityComponentManager &_ecm,
		gz::sim::EventManager &_eventMgr);
	void PreUpdate(const gz::sim::UpdateInfo &_info,
		       gz::sim::EntityComponentManager &_ecm) final;
	void PostUpdate(const gz::sim::UpdateInfo &_info,
			const gz::sim::EntityComponentManager &_ecm) final;
private:
	// parent model
	gz::sim::Model _model{gz::sim::kNullEntity};
	// UART
	int _uart_fd = -1;
	std::string _uartDevice = "/dev/pts/15"; // use socat virtual port: $ socat -d -d pty,raw,echo=0 pty,raw,echo=0
	unsigned int _baudRate = 115200;
	float _noiseStdDev = 0.0f;
	// Position Noise
	std::default_random_engine _randGen;
	std::normal_distribution<float> _noiseDist{0.0f,_noiseStdDev}; // mean and stddev
	// Publish Timing
	double _updateHz = 10.0;
	std::chrono::steady_clock::duration _updatePeriod;
	std::chrono::steady_clock::time_point _lastUpdateTime;
	// subscribe
	void OnPoseInfo(const gz::msgs::Pose_V& msg);
	// send UWB data
	void SendUwbData(const gz::math::Vector3f& pos);
	// Add your private member variables and methods here
	gz::transport::Node _node;
} // end namespace custom
// UwbPosition.cpp
#include "UwbPosition.hpp"
#include <cstring>
#include <chrono>
using namespace custom;
// Register the plugin
GZ_ADD_PLUGIN(
	custom::UwbPositionPlugin,
	gz::sim::System,
	custom::UwbPositionPlugin::ISystemPreUpdate,
	custom::UwbPositionPlugin::ISystemPostUpdate
GZ_ADD_PLUGIN_ALIAS(custom::UwbPositionPlugin, "custom::UwbPositionPlugin")
void UwbPositionPlugin::Configure(
	const std::shared_ptr<const sdf::Element>& _sdf,
	gz::sim::EntityComponentManager& _ecm,
	gz::sim::EventManager& _eventMgr)
	this->_model = gz::sim::Model(_entity);
	if(!this->_model.Valid(_ecm)){
		gzerr <<"[UwbPositionPlugin] Model is invalid."<<std::endl;
		return;
	// Load SDF Parameters (optional)
	if (_sdf->HasElement("uart_device")) {
		this->_uartDevice = _sdf->Get<std::string>("uart_device");
	if (_sdf->HasElement("baud_rate")) {
		this->_baudRate = _sdf->Get<unsigned int>("baud_rate");
	if (_sdf->HasElement("update_rate")) {
		this->_updateHz = _sdf->Get<double>("update_rate");
	if (_sdf->HasElement("noise_stddev")) {
		this->_noiseStdDev = _sdf->Get<float>("noise_stddev");
		this->_noiseDist = std::normal_distribution<float>(0.0f, this->_noiseStdDev);
	*/ // end SDF Parameters
	std::cout<<"configuration called"<<std::endl;
	gzmsg << "Configure Called!"<<std::endl;
	// subscribe data
	this->_node.Subscribe("/world/default/pose/info",&UwbPositionPlugin::OnPoseInfo,this);
	// Publish timing
	this->_updatePeriod = std::chrono::duration_cast<std::chrono::steady_clock::duration>(std::chrono::duration<double>(1.0/this->_updateHz));
	this->_lastUpdateTime = std::chrono::steady_clock::now();
	// open UART port
	this->_uart_fd = ::open(this->_uartDevice.c_str(), O_RDWR|O_NOCTTY|O_NONBLOCK);
	if(this->_uart_fd<0){
		gzerr << "[UwbPositionPlugin] Failed to open UART port"<<this->_uartDevice<<" : "<<strerror(errno)<<std::endl;
		return;
	struct termios tty{};
	if(tcgetattr(this->_uart_fd, &tty)!=0){
		gzerr <<"[UwbPositionPlugin] Err from tcgetattr: "<<strerror(errno)<<std::endl;
		return;
	cfsetospeed(&tty,B115200);
	cfsetispeed(&tty,B115200);
	tty.c_cflag |= (CLOCAL | CREAD);    // Enable receiver
	tty.c_cflag &= ~CSIZE;
	tty.c_cflag |= CS8;                 // 8-bit
	tty.c_cflag &= ~PARENB;             // No parity
	tty.c_cflag &= ~CSTOPB;             // 1 stop bit
	tty.c_cflag &= ~CRTSCTS;            // No flow control
	tty.c_lflag = 0;                    // No canonical, echo
	tty.c_oflag = 0;
	tty.c_cc[VMIN] = 0;
	tty.c_cc[VTIME] = 1;
	if(tcsetattr(this->_uart_fd, TCSANOW, &tty)!=0){
		gzerr<<"[UwbPositionPlugin] Error from tcsetattr: "<<strerror(errno)<<std::endl;
		return;
	gzdbg <<"[UwbPositionPlugin] Plugin configured. Sending to "<<this->_uartDevice<<std::endl;
void UwbPositionPlugin::PreUpdate(const gz::sim::UpdateInfo &_info,
	// Implement pre-update logic here
	if(_info.paused||this->_uart_fd <0){ return; }
	auto now = std::chrono::steady_clock::now();
	if(now-this->_lastUpdateTime< this->_updatePeriod){ return; }
	this->_lastUpdateTime = now;
	// Get pose
	// auto poseOpt = _ecm.Component<gz::sim::components::Pose>(this->_model.Entity());
	// if (!poseOpt) {
	// 	gzerr << "[UwbPositionPlugin] No pose component found." << std::endl;
	// 	return;
	// gz::math::Vector3d pos = poseOpt->Data().Pos();
	// gz::math::Vector3f pos_f(
	// 	static_cast<float>(pos.X()),
	// 	static_cast<float>(pos.Y()),
	// 	static_cast<float>(pos.Z())
	// // Add Gaussian noise
	// pos_f.X() += this->_noiseDist(this->_randGen);
	// pos_f.Y() += this->_noiseDist(this->_randGen);
	// pos_f.Z() += this->_noiseDist(this->_randGen);
	// // Send over UART
	// this->SendUwbData(pos_f);
void UwbPositionPlugin::OnPoseInfo(const gz::msgs::Pose_V &msg)
	gzmsg << "OnPoseInfo called!"<<std::endl;
	for(int i=0;i<msg.pose_size();++i)
		const auto& poseMsg = msg.pose(i);
		if(poseMsg.name()=="x500_0")
			auto posMsg = poseMsg.position();
				static_cast<float>(posMsg.x()),
				static_cast<float>(posMsg.y()),
				static_cast<float>(posMsg.z())
			std::cout<<"onpose called: "<<posMsg.x()<<" "<<posMsg.y()<<" "<<posMsg.z()<<std::endl;
void UwbPositionPlugin::SendUwbData(const gz::math::Vector3f &pos)
	gzmsg << "SendUwbData called!"<< std::endl;
	if (this->_uart_fd < 0) return;
	const uint8_t LOCATION_DATA = 0x10;
	const uint8_t CTRL_IDLE = 0x20;
	const uint16_t END_CODE = 0xFFFF;
	uint8_t buffer[20] = {};
	size_t offset = 0;
	float x = pos.X();
	float y = pos.Y();
	float z = pos.Z();
	// Pack data
	buffer[offset++] = LOCATION_DATA;
	std::memcpy(&buffer[offset], &x, sizeof(float)); offset += sizeof(float);
	std::memcpy(&buffer[offset], &y, sizeof(float)); offset += sizeof(float);
	std::memcpy(&buffer[offset], &z, sizeof(float)); offset += sizeof(float);
	buffer[offset++] = CTRL_IDLE;
	std::memcpy(&buffer[offset], &END_CODE, sizeof(uint16_t)); offset += sizeof(uint16_t);
	ssize_t bytes_written = write(this->_uart_fd, buffer, offset);
	std::cout<<"written bytes "<< bytes_written<<std::endl;
	gzmsg << "written bytes: " << bytes_written << std::endl;
void UwbPositionPlugin::PostUpdate(const gz::sim::UpdateInfo &_info,
	// Implement post-update logic here
I made this plugin for subscribe gz-local position of x500, and send xyz coordinate to UART port… I configured file settings following Gazebo Plugins | PX4 Guide (main) .
but I run $ make px4_sitl gz_x500….
this plugin is not loaded… plz give many advice….
Did you follow the docs?
yeah, I followed the docs
<!-- PX4-Autopilot/src/modules/simulation/gz_bridge/server.config -->
<server_config>
  <plugins>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-physics-system" name="gz::sim::systems::Physics"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-user-commands-system" name="gz::sim::systems::UserCommands"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-scene-broadcaster-system" name="gz::sim::systems::SceneBroadcaster"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-contact-system" name="gz::sim::systems::Contact"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-imu-system" name="gz::sim::systems::Imu"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-air-pressure-system" name="gz::sim::systems::AirPressure"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-air-speed-system" name="gz::sim::systems::AirSpeed"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-apply-link-wrench-system" name="gz::sim::systems::ApplyLinkWrench"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-navsat-system" name="gz::sim::systems::NavSat"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-magnetometer-system" name="gz::sim::systems::Magnetometer"/>
    <plugin entity_name="*" entity_type="world" filename="gz-sim-sensors-system" name="gz::sim::systems::Sensors">
      <render_engine>ogre2</render_engine>
    </plugin>
    <plugin entity_name="*" entity_type="world" filename="libOpticalFlowSystem.so" name="custom::OpticalFlowSystem"/>
    <plugin entity_name="*" entity_type="world" filename="libGstCameraSystem.so" name="custom::GstCameraSystem"/>
    <plugin entity_name="*" entity_type="world" filename="libTemplatePlugin.so" name="custom::TemplateSystem"/>
  </plugins>
</server_config>
but, this plugin is not running… I changed the filename and class name to “TemplateSystem”
