I am facing an issue when trying to exit Offboard mode and switch the drone to Loiter (NavState = 5). I am following the example and guidelines from the px4_ros_com repository.
My Configuration
- Language: Python
- Platform: PX4
- Firmware version: v1.13
What I Am Doing
I execute a takeoff command:
self.publish_vehicle_command(VehicleCommand.VEHICLE_CMD_NAV_TAKEOFF, param1=1.0, param7=5.0)After this, the drone switches to a hover mode (I assume this is Loiter).
I switch the drone to Offboard mode:
self.publish_vehicle_command(VehicleCommand.VEHICLE_CMD_DO_SET_MODE, param1=1.0, param2=6.0)After this, the drone successfully enters Offboard (NavState = 14), and I can control it.
I attempt to switch back from Offboard to Loiter:
self.publish_vehicle_command(VehicleCommand.VEHICLE_CMD_DO_SET_MODE, param1=1.0, param2=5.0)However, the
NavStateremains 14 (Offboard), and the drone continues in this mode.
Expected Behavior
After sending the command to switch to Loiter, the drone should transition to NavState = 5 and begin hovering at its current position.
Actual Behavior
The NavState remains 14 (Offboard), and the switch command has no effect on the mode.
Question
How can I reliably exit Offboard mode and switch to Loiter? Are there additional conditions or settings in PX4 that need to be considered?
I would greatly appreciate any recommendations or explanations!
